Previous in Forum: energymeter calculation   Next in Forum: CT Excitation Curve and Accuracy Class
10 comments
Good Answers: 170
Synchronous Motor
05/31/2011 12:43 PM
Can synchronous motor be classified under Three Phase Induction Motors?
Re: Synchronous Motor
05/31/2011 1:48 PM
The term "induction motor" is interchangeable with the term "asynchronous motor'.
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
06/01/2011 4:21 AM
Errrrrrrrrrr,
Not possible.
If you can't find a way, make one........
Good Answers: 804
03/04/2012 2:54 PM
"The term "induction motor" is interchangeable with the term "asynchronous motor'."
I don't see the problem with this statement, I don't think it should have been voted "Off Topic". But maybe is was a tad bit too terse for some. How abaout this:
The term "induction motor" is interchangeable with the term "asynchronous motor' and the "a" in asynchronous means NOT synchronous. So therefore a synchronous motor and an asynchronous (induction) motor are by definition not the same thing.
03/17/2012 2:32 AM
Sorry.. my mistake.. I read as synchonous instead of asynchronous..
India - Member - New Member
05/31/2011 2:02 PM
Synchronous motors and Induction motors are entirely different
Synchronous motors has features like constant speed and rotor has permanent magnet
But in induction motors it is different speed varies according to load and rotor are short circuited bars
any way synchronous motors and Induction motors are entirely different in construction, operation and working principle
key questions why, what & how - just think
06/01/2011 1:08 AM
for short, no
The time is ......now
Good Answers: 44
06/01/2011 10:35 AM
Which one of the three phases would you like it to be synchronous with?
Salient-pole, single-phase, induction motors can be made by grinding flats onto specific portions of the rotor. Then the motor, usually 1800 rpm (previously 1725 rpm) or 3600 rpm (previously 3450 rpm), is a synchronous induction motor...single phase.
06/01/2011 11:49 AM
I think you think a lot before asking, little afraid to say something.
IM works under the principle of mutual induction followed by magnetic attraction with some slip where as Synchronous motor under direct magnetic attraction.
Can you say why you asked the question?
06/05/2011 1:36 AM
We don't class them as an induction motor.
As I see it, a synchronous is a specialized type of induction motor, it starts as an induction motor, and after the motor winding is energized, it becomes a synchronous motor. I worked on one, where, because the field wasn't getting energized, it started and ran as an induction motor for a little while before tripping out.
03/04/2012 11:31 AM
The answer is NO.
DHAYANANDHAN.S
Register to Reply 10 comments
Anonymous Poster (1); cuba_pete (1); dhayanandhan (1); JRaef (1); justinanto1987 (2); nikolay (1); parvathaneni (1); vtbgiraud (1); Yuri B. (1)
