Previous in Forum: Integrated Steel Plant   Next in Forum: valves spec
Service Life of Piping System
06/01/2011 5:34 AM
how can i calculate service life of a piping system?.
thanks
Re: Service life of piping system
06/01/2011 5:39 AM
Well, when is the plant due to be demolished?
Good Answers: 181
Re: Service Life of Piping System
06/01/2011 7:39 AM
Wait until it springs a leak!
Good Answers: 61
06/01/2011 11:49 AM
piping engineer,
You wrote:
"How can i calculate service life of a piping system?"
I am sure that you had something specific in mind but this is not a valid question as written. You do not "calculate the service life of a piping system."
The Client, using financial data for return on investment (ROI) decides the minimum plant life. The plant life may be set at 20, 25, 30 years or something far different.
The piping engineer then uses this "plant life" number along with worst case corrosion rates (chemical vs. material) when calculating the minimum wall thickness of the piping systems.
Is this really what you had in mind?
Or was there something else you needed?
Do it once and do it right
Register to Reply 3 comments
PennPiper (1); PWSlack (1); TonyS (1)
