Previous in Forum: valves spec   Next in Forum: Heat Treatment requirement per AD2000-Merkblatter
10 comments
Are There Exceptions?
06/01/2011 6:35 PM
As you all know, with increase in temperature, all materials expand, "Ivar" included. Is there no exception? No fluid or fluid mix that shrinks with temperature (chemical reaction that reverses in colder temperatures)?
I am interested in temperatures between -10 and 100 deg C and pressures between 0.1 and 50 bar.
Pathfinder Tags: mechanical engineering
Good Answers: 88
Re: Are there exceptions/
06/01/2011 6:45 PM
I know a material that shrinks untill down to 4 degrees Celsious and then getting colder expands again. But then at 0 Degrees solidifies. Useless stuff. S.M.
06/01/2011 7:13 PM
Yes, you are right. Unfortunately the range is to small. Thanks.
Good Answers: 183
06/02/2011 10:01 AM
Not good, it changes phase at less than 100°C if pressure goes down !
Good Answers: 143
Re: Are There Exceptions?
06/01/2011 7:37 PM
What about Kevlar? Many of the fiber materials that we use in composites have negative CTEs.
06/01/2011 7:56 PM
06/01/2011 10:29 PM
Thank you very much. What I am searching for is a practical way to make a reversed thermo-siphon, where the heat to go from top to bottom based on gravitational energy, with no moving parts aside from the fluid.
06/01/2011 11:32 PM
Well, that's quite a different thing. What else do you have to tell us?
06/02/2011 12:37 AM
So, what you have in mind is a perpetual motion machine?
It will never happen, no matter what the motive material's properties are.
Not even flubber will work.
06/02/2011 10:24 PM
I don't want to make a perpetuum mobile. The energy is there where is temperature difference, it does not matter if you use a thermo-siphon or a thermocouple to harvest it. I think that a lot of junction pairs can do the job, but is expensive to install a lot of them, with circulating pumps, etc. to spread the heat around. It will work as long as there is temperature difference, and transfer heat from hot junction to cold junction, it does not matter which one is up. What I have in mind is more like storing the heat in the underground, without big investment. When the temperature above is higher then below, the process starts by itself, working like a one way road. You can do a lot of things with that heat in the winter.
06/03/2011 12:53 AM
Zirconium tungstate has a fairly stable negative thermal coefficent from about few degrees kelvin to around 1000 degrees kelvin.
Register to Reply 10 comments
Anonymous Poster (1); jerybaciu (3); lyn (2); Mikerho (1); nick name (1); SimpleMind (1); TVP45 (1)
