Previous in Forum: Shaft Coupling   Next in Forum: Is Oven Baking Required for 6mw Alternator Refurbishment?
Tensile Testing System
06/02/2011 4:10 PM
I need 3 mm/min constant speed with 2500 N force in tensile testing system(portable tensile testing machine about 20 kg). I do not have much information about motors. To get this low speed, what type of motor should be used? Our power transmission system is rack and pinion ( the pinion should be coupled with the motor shaft)and the required rotational speed of the pinion gear is 0.019 rpm. Our first choice should be DC motor.Is there any DC motor system with speed reducer to get this speed?
Re: help me plz
06/02/2011 4:42 PM
Good Answers: 101
Re: help me plz
06/02/2011 5:06 PM
You need to design the system using hydraulics. Hydraulics offer the highest level of precision for tensile testing machines, which is why they all use hydraulics. You will find that a rack and pinion style design will not be accurate and repeatable due to varying forces and frictions which you need to overcome. You can easily control an exact force at an exact rate of speed as slow or fast as you want using hydraulics.
You can use an electric motor (if electricity is available) or a gasoline hydraulic power pack, valves, filter, cylinder, etc to make it mobile.
I think you are attempting to create something which is overcomplicated, and under the level of accuracy needed for a testing machine.
"Make things as simple as possible, but no simpler" -Einstein
Good Answers: 101
Re: help me plz
06/02/2011 5:17 PM
As far as you actual question about the DC motor, yes many are available, you can use DC or AC as long as you get a good motor speed controller, and choose a motor that is rated to run at a reduced speed without the fear of overheating. You should be able to find ample information with a quick and simple google search of "motor speed controllers" or "variable frequency drives". If you are on an extreme budget, and the motor is small enough (you never stated the power requirement for the motor) you could use a simple PWM (pulse width modulation) to vary the speed of the DC motor.
But in the end, your contraption is highly overcomplicated, and highly susceptible to poor repeatability over time.
Good Answers: 181
Re: Tensile Testing System
06/03/2011 2:24 AM
This was all discussed in http://cr4.globalspec.com/thread/68644 the advice then was NOT to go with a rack and pinion.
Register to Reply 4 comments
lyn (1); RVZ717 (2); TonyS (1)
