Previous in Forum: How Do I Ghost a Hard Drive?   Next in Forum: Shared Drives
RS232 cable + USB cable?
06/03/2011 11:08 AM
Hi,
I am trying to print out test reports from an electrical safety device which has an RS-232 interface. I admit this is my first time but I can write codes in C and C++. The question is
Q) Can I buy a RS232 cable which has rs232 on one side and USb on the other end and is it possible to work with it.
Good Answers: 58
Re: RS232 cable + USB cable?
06/03/2011 11:12 AM
06/03/2011 11:16 AM
Yes.
http://www.google.co.uk/search?q=rs232+usb
Cheap & easy to use (some are plug'n'play, some need drivers that come with them). If you're using a laptop, make sure that it's compatible (some of the cheaper ones are limited when used with a laptop, and won't work with some PLCs).
When installed, it will look just like a COM port on the PC/laptop.
Good Answers: 52
06/03/2011 11:25 AM
The short answer to your question is yes.
I am guessing your pc doesn't have an rs232 port. If this is the case and you want to use a usb to rs232 adapter to work with a device that only has an rs232 interface then you should be able to find something that works.
I have used these cables before with my own software with lots of success, for the most part they seem to do a good job replicating an rs232 serial port. I think the voltages are a little different and they are not exactly the same but for most applications they work fine.
I have heard that some adapters don't work and others do, I have used 3 different adapters and found all worked for my applications. I know two of them used the prolific driver and I would imagine the chip sets were the same, while the other used something else.
A related topic, and likely not that important to your question, a USB to parallel port adapter is a completly different story where you are mostly SOL.
Register to Reply 3 comments
frankd20 (1); JohnDG (1); KJK/USA (1)
You might be interested in: Cable Assemblies, Cable Laying Services, USB Connectors
