Previous in Forum: Tractor PTO Powered Battery Charger   Next in Forum: Industrial Circuit Simulation
Nitriding Case hardening
06/04/2011 2:04 AM
In swtichgear mechanism 18 mm diameter shaft is used.
Just now we had changed our design form through hardening to Nitriding case hardening. now my question is
1) what are the output paramter that we can check to check case hardening (through Nitriding ) proces validation.
2) what are the cirticla paramter of nitriding case hardening.
3) how case hardening thourhg nitriding , nitrocarburising , carborising is different in terms of benifits and loss.
Re: Nitriding Case hardening
06/04/2011 11:02 PM
You may have to refer the following documents for a clear and comprehensive information you are seeking.
SAE AMS 2759/8 Society of Automotive Engineers, Inc., Aerospace Material Specification: Ion Nitriding
SAE AMS 2759 Society of Automotive Engineers, Inc. ,Aerospace Material Specification: Heat Treatment of Steel Parts: General Requirements
ASTM E384 American Society for Testing and Materials Specification, Standard Test Method for Microindentation Hardness of Materials
ASTM A370 American Society for Testing and Materials Specification, Standard Test Methods and Definitions for Mechanical Testing of Steel Products
Good Answers: 25
06/05/2011 7:48 AM
Heat treatment process will depend on:-
1.Material of the shaft.
2.How much skin hardness you need.
3.Depth of the of the skin hardness.
06/06/2011 12:34 AM
Material : En19
18 mm Diameter and 175 mm length ( Machining is not uniform)
Requried case hardening depth : 0.1 to 0.15 mm;
Hardness : 500 to 600 hv
For above specification Nitriding is done.
so which paramter of nitriding process shall be monitored and its value.
Good Answers: 25
06/06/2011 3:06 AM
Please visit this web site:-http://www.keytometals.com/articles/art117.htm.
Register to Reply 4 comments
krishnan.ng (1); suresh sharma (2); vikash.agrawal (1)
