Previous in Forum: Flowmeter   Next in Forum: Aluminum Router
Calibration Instruments
06/05/2011 12:53 AM
hai, please tell me which instruments are used for calibration of temperature,pressure,level and flow?
Re: calibration instruments
06/05/2011 1:00 AM
Do you have any thoughts on the subject?
06/05/2011 1:06 AM
ya.. i know about dead weight tester, comparator and temp.bath .....i want to know about remaining instruments
Good Answers: 444
Re: Calibration Instruments
06/05/2011 2:54 PM
Must be a trick question but here goes...How about a Thermometer, Manometer, Meter-Stick, Bucket (or Scale) and Stopwatch?
Seriously now, what are the parameters of the things you are trying to measure? For example measuring the temperature of liquid nitrogen can't be done with a calibrated mercury thermometer; etc.
06/05/2011 10:02 PM
Hi,
Try a bucket of steam,sky hook,metric adjustable wrench,hydraulic acid....
"The older I get -The better I was"
06/09/2011 11:07 PM
Temperature = temperature bath
Pressure = dead weight tester
We Stare Because We Care
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
06/12/2011 1:27 AM
For temperature if it is RTD or thermocouple sensor you can use dry block calibrator and indicator can be calibrated using RTD and thermocouple signal source.
Pressure instruments can be calibrated using dead weight testers or hand pump pressure calibrators.
For level you can use a calibrated level transmitter.
For flow you can use a calibrated flow meter.
If you can't find a way, make one........
07/18/2011 2:01 PM
You can use Yokogawa or Fluke instruments
Register to Reply 7 comments
Banana86 (1); bully (1); justinanto1987 (1); lyn (1); m_ravi1110 (1); RAMConsult (1); wrenchpuller (1)
