Previous in Forum: Energizing 750MVA Transformer 275KV/400KV   Next in Forum: FACTS Devices
FACTS Devices
06/07/2011 1:37 AM
how the svc(FACTS Devices) works.its operating principle
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
Re: FACTS Devices
06/07/2011 5:11 AM
A Static VAR Compensator (or SVC) is an electrical device for providing fast-acting reactive power on high-voltage electricity transmission networks. SVCs are part of the Flexible AC transmission system device family, regulating voltage and stabilizing the system. The term "static" refers to the fact that the SVC has no moving parts (other than circuit breakers and disconnects, which do not move under normal SVC operation). Prior to the invention of the SVC, power factor compensation was the preserve of large rotating machines such as synchronous condensers. An SVC provides benefits at the transmission, distribution and end user level. An SVC provides benefits at the transmission, distribution and end user level.
The SVC is an automated impedance matching device, designed to bring the system closer to unity power factor. If the power system's reactive load is capacitive (leading), the SVC will use reactors (usually in the form of Thyristor-Controlled Reactors) to consume VARs from the system, lowering the system voltage. Under inductive (lagging) conditions, the capacitor banks are automatically switched in, thus providing a higher system voltage. They also may be placed near high and rapidly varying loads, such as arc furnaces, where they can smooth flicker voltage.
http://www.amsc.com/pdf/PESSVC_BRO_0410_A4_forweb.pdf
Vinu_Answers Sure_Answers
Sure Answers Always
Register to Reply 2 comments
