Previous in Forum: Caustic Handling   Next in Forum: Insulation
Queries Regarding Use of ASME SEC. VIII for Valves.
06/07/2011 2:45 AM
Hi,
I have a query regarding the ASME SEC. VIII. BPVC.
1. We regularly referred ASME SCC VIII.-Div 1 for non-customer side flange design. There are 2 divisions of ASME SEC. VIII, i.e. Div. 1 & Div. 2 (alternative Rules), which to be preferred when?
2. Can we keep the thickness of bonnet flange(T1) less than non-customer side (i.e. bonnet side) body flange thickness (T), if supported by calculations? (Please refer ASME SEC. VIII Div. 1. Mandatory Appendices, 1.6 Dished Covers (Bolted Flange) page 333.)
3. Please refer the SCOPE of ASME Sec. VIII. Div 1. U-1 (e), Scope says, we can't use the code for pipe, pumps & valves etc.
Kindly refer below statement from ASME Sec. VIII. Div 1. U-1 (e), -
(e) piping components, such as pipe, flanges, bolting,
gaskets, valves, expansion joints, fittings, and the pressure
containing parts of other components, such as strainers
and devices which serve such purposes as mixing, separating,
snubbing, distributing, and metering or controlling
flow, provided that pressure containing parts of such components
are generally recognized as piping components or
accessories;
Please Suggest,
Regards,
Ratnakar
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
Re: Queries Regarding Use of ASME SEC. VIII for Valves.
06/09/2011 2:59 AM
Hi,
Why don't use ANSI/ASME B16.34 which is specific for valve design?
