Previous in Forum: Queries Regarding Use of ASME SEC. VIII for Valves.   Next in Forum: Uses of Technical Alcohol
Insulation
06/08/2011 5:55 AM
Dear sir,
We have a storage tank with FRP a sa material of construction.
we have to maintain temperture of 14 deg c of tank fluid.
Is it possible to provide insulation to FRP tank?
Thanks
Be not afraid of growing slowly, Be afraid only of standing still.
Re: insulation
06/08/2011 6:03 AM
Yes.
Good Answers: 61
Re: insulation
06/08/2011 11:40 AM
bhalchandra
As already stated you can insulate an FRP tank.
But, You must remember that insulation by itself will not keep your fluid at the desired temperature unless there is some form of heat input. This can be by circulation to an outside heater or by an in-tank heater.
The insulated tank with no heat input will, over time seek equilibrium with the ambient temperature surrounding the tank.
Do it once and do it right
Good Answers: 38
Re: insulation
06/08/2011 12:28 PM
To add to the fine advice given above....
Yes, it is possible to add insulation, but this requirement should be considered at the time of tank purchase.
Metal and FRP tanks can be equipped with stiffeners and tie-points that will greatly ease the installation and attachment of insulation.
Was this tank used for some other service in the past ? (silly question...)
Re: Insulation
06/08/2011 7:02 PM
I'd have it sprayed with two part urethane foam. Then if a more durable finish is needed, you can paint the foam.
You may still need a heater.
Register to Reply 4 comments
lyn (1); MJCronin (1); PennPiper (1); PWSlack (1)
