Previous in Forum: Water Pumps   Next in Forum: Wire Size When Replacing Machine.
Automatic Transfer Switch
06/07/2011 1:07 PM
hay!
I need the circuit to implement the ATS for generator, my task is:
when mains is available the load should be running from mains, when mains fails the generator will connected with the load that can be started either manually or automatically. Now suppose mains comes back, load must be run by the mains and after a few minutes the generator must be automatically off.
If anyone can help me,,,
Regards!
Good Answers: 58
Re: Automatic Transfer Switch
06/07/2011 1:35 PM
  1. Go to Google.
  2. In the search window enter "ATS Schematic"
  3. Press "Enter"
Within 0.16 seconds, 392,000 result will be revealed to you.
In case you were not aware, "hay" is not an appropriate greeting.
"Hay" is what horses, cattle, and many other livestock consume for sustenance.
Good luck with your search.
06/07/2011 1:58 PM
Or just search "ATS Schematic" within the CR4 forums, all the answers are right in front of you. Take a couple of seconds to look for them yourself before asking others.
Good Answers: 58
06/07/2011 3:12 PM
An even better idea, he's already here!
India - Member - New Member
06/10/2011 6:23 AM
Why to re-invent wheel.
ATS are manufactured by DG set manufacturer are readily available with all features (most of which you have not mentioned).
Visit cummins web site for more information.
When was last time you did something for first time.
Register to Reply 4 comments
Anonymous Poster (1); Happy singh (1); KJK/USA (2)
