Previous in Forum: Wire Size When Replacing Machine.   Next in Forum: Charging 750MVA 300/400KV Transformer
How we can calculate “tone” in HVAC system?
06/07/2011 5:03 PM
How we can calculate "tone" in HVAC system? What is the perfect tone of mentioned below specification? 1. Model. PX150HDRGKGKGN AABNNNSS Unit Supply: 208/230-3-60Volts-Ph-Hz, Compressor: 230-3-60, FLA22.0 EA,LRA: 1350 EA Fan Motor: 230-3-60,FLA: 3.8 EA, LRA: 15.0, HP: 3/4 Blower Motor: 230.3.60, FLA: 13.8, LRA: 89.0, HP: 5 Heater: 230-3-60 KW:25 AMPS:62.8 Refrigerant R22 145 0z Each System Test Pressure 300 PSIGHS150PSIGLG 2. Model. PX225HDSGJGNAABNNNSS Unit Supply:208/230-3-60, , Compressor :208/230-3-60, FLA :35.0 EA, LRA: 232.0 EA, Fan Motor: 208/230-3-60, FLA: 3.7 EA, LRA: 17 EA, HP: ¾ EA Blower Motor: 208/230.3-60, FLA: 14.5, LRA: 87.0, HP 5, Heater:230-3-60 KW: 20 , AMPS: 50.2 Refrigerant R22 235 0z Each System, Test Pressure 300 PSIGHS150PSIGLS, thanks
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
Re: How we can calculate “tone” in HVAC system?
06/07/2011 5:07 PM
It's ton, not tone. 1 ton of air conditioning is equal to 12,500 BTU/hour.
I'm not going to do your job for you, so you'll have to find an on-line servant.
Can you Google?
How to Search the Internet - wikiHow
06/07/2011 5:14 PM
I thought maybe since they are 60 Hz systems, the perfect tone would therefore be 60 Hz.
Hmmmm?
06/07/2011 7:21 PM
Well, only at sea level. See, Hz goes up with pressure. That's why Europe runs at 50 Hz. They are closer to sea level.
North America, being higher, runs at 60 Hz.
So, at 300PSI the tone would not be 60 Hz but 1285.7142 Hz.
Register to Reply 3 comments
