Previous in Forum: Phosphorus Bronze Bushes-Soaking in Oil   Next in Forum: Criticality defination for stress analysis Level-I
12 comments
Protective Coating on SS 310S Tank
06/07/2011 6:43 PM
Hi Guys,
Can you suggest me what protective coating (on external surface) we can use on SS 310S Tank? We are using Sulphuric Acid at 30 deg C at atmospheric pressure.
Thanks,
Salman
Re: Protective Coating on SS 310S Tank
06/07/2011 8:10 PM
Contact these people. I'm a little behind on the very latest coatings systems, but I've used their industrial coatings. They should have something that will work well. They are large enough that they should have a location somewhere near you.
http://www.sherwin-williams.com/
06/08/2011 3:45 AM
Not sure you will find an answer here but might help:
http://www.finishing.com/152/90.shtml
Sulfuric acid is pretty aggressive - good luck.
06/08/2011 6:10 AM
What concentration?
(It's a good idea to quote the concentration as the sulpuric acid/steels system behaved differently depending on concentration.)
Is there a containment problem at the facility that needs to be addressed instead?
06/08/2011 5:36 PM
The concentration is 99% and I just wanted to know what coating we can apply on external surface. Previously, it was insulated because we were dealing with hot sulphuric acid but we have changed the process and now it's at ambient temp. As we are pulling out the lagging, I wana check what coating we should apply on surface to avoid corrosion, do we need it?
06/08/2011 11:08 PM
At that temperature and pressure have you considered a polyolefin tank?
bioramani
Hobbies - CNC - New Member
06/08/2011 11:36 PM
If a 99% acid is not corroding the inside, what is going to corrode the outside?? SS310 is high chromium, and should be just fine bare.
06/09/2011 6:50 AM
I agree. Any paint will eventually fail and need to be maintained. I'd leave it alone.
I was thinking it may have been for aesthetic reasons. If that was the case, there are products that would work.
06/09/2011 12:07 AM
I was just trying to be on safe side
Popular Science - Weaponology - New Member India - Member - New Member
06/09/2011 6:32 AM
use epoxy glass flake coating.
demech
06/09/2011 10:26 AM
A few questions: What is the size of the tank? Can the tank be transported for coating or does it have to be coated on-site? If the tank is transportable, then it may be a candidate for a Fluoropolymer coating such as HALAR ECTFE which has excellent resistance to Sulfuric Acid at the conditions you mentioned. This is a multiple coat multiple bake coating process and therefore needs to be sent to an applicator versed in its application. Typical application thickness is about 30 mils per side. Southwest Impreglon Inc. in Houston, Texas is one applicator for these types of coatings if the tank is transportable and fits into their ovens.
Good Answers: 67
06/19/2011 9:15 AM
Absolutely no need to worry, you can leave it without any coating on SS 310S.
10/09/2024 2:59 AM
...provided there is no water ingress to the <...99%...sulphuric acid...at ambient temp...> that might lower the concentration!
Register to Reply 12 comments
bioramani (1); drbobwoolery (1); dryfly (1); kramarat (2); pritam (1); PWSlack (2); sam12 (2); sanjaykangralkar (1); Viper18 (1)
