Previous in Forum: Design of Exhaust Band Clamp   Next in Forum: Automobile Two Wheeler Gearing Arrangement
Windshield Edge Protection Tape - Necessary?
06/08/2011 5:49 AM
Automotive Front Windshield/Glass edges are prone to residual stress. So improper fitment or unfortunate hit by external force may lead to cracks.
The cracks are normally generated from the edge only.
To prevent the crack generation, teflon tape is adhered throughout the periphery to reduce the duct accumulation and friction contact between the external force and the windshield/glass.
I think, application of Tape is cost increase, instead Glass/Windshield should be designed to bear tht stress.
Re: Windshield Edge protection tape - necessary?
06/08/2011 6:05 AM
It's not just about stress cracks. You would also have to design the glass to fit directly against metal and not leak water.
I think you'll find that a 4 meter piece of tape is much less expensive than redesigning both the glass and the opening to work properly without it.
Good Answers: 266
06/08/2011 7:11 AM
It's there to seal the window to the opening, make it fast so it does not move around and I believe it's butyl rubber.
06/08/2011 7:15 AM
You're right! It works great.
Good Answers: 44
Re: Windshield Edge Protection Tape - Necessary?
06/08/2011 10:28 AM
Cracks generally start from the edge because of the old adage..."between a rock and a hard place". The flexibility of the material is greatly reduced on impacts due to the anvil on one side. Stress fractures due to freezing conditions occur due to lack of movement, again, because the glass is affixed to to an object, which changes shape at a slower rate, and is attempting to relieve stress.
Register to Reply 4 comments
cuba_pete (1); kramarat (2); ozzb (1)
