Previous in Forum: Isothermal Annealing of EN355 Forging   Next in Forum: Laser / Inkjet Marker
9 comments
help me to find a process to do deburring in a 40ft length pipe
06/09/2011 11:04 PM
Hi all,
I need to do deburring in a perforated pipe of 40ft. hole dia is 10mm, wall thickness is 12mm mtl is L80 and nearly 2000+ holes we made over the length of the pipe. for external deburring we use abrasive belt for internal we use die grinder with grinding wheel. but my boss feels like it is not that much ok. can anybody suggest me a good process.
This discussion was "closed" on 06/10/2011 8:57 AM. No new comments are allowed.
Message from admins:
duplicate discussion please continue discussion in http://cr4.globalspec.com/thread/69390
Re: help me to find a process to do deburring in a 40ft length pipe
06/09/2011 11:52 PM
I'd contact Brush Research Manufacturing [www.brushresearch.com] - they make all kinds of deburring products including some for IDs - like these:
http://www.brushresearch.com/product-line.php?line=1
06/10/2011 1:08 AM
Thank you very much for your info..i will check.
Good Answers: 18
06/10/2011 3:31 AM
Hi castkarthick,
Check out this link they might have something to suit your application.
http://www.noga.com/nogaProducts.php?catID=rvcn
Best regards,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
06/10/2011 3:50 AM
Hi,
this tools wont helpful, because the pipe externala and internal surface is concave and convex. also our pipe is very lengthy one. nearly 2000+ holes need to be deburred. anyway thanks for your kind info.
Good Answers: 18
06/10/2011 4:11 AM
Hi castkarthick,
Wow, fast response, thanks, what is the pipe ID (Inside Diameter).
Best regards,
John
06/10/2011 4:21 AM
ID is 6".
Good Answers: 18
06/10/2011 5:00 AM
Hi again castkarthick,
Quite a large bore! might be worth e-mailing the deburring tool people as they might have other products more suited to your application.
Best of luck in your search,
John
06/10/2011 5:03 AM
Hi Jes,
i already sent a mail to noga, waiting for reply.
Regards,
karthick.n
06/10/2011 5:15 AM
same time i have 3.5" id also to deburr.
Register to Reply 9 comments
castkarthick (5); dryfly (1); jesw55 (3)
