Previous in Forum: Automatic Star/Delta 3 Phase Motor Starter   Next in Forum: Some Electrical Engineering Questions
ATEF
06/12/2011 10:47 AM
i have problem in 3 genset operated to gather in parallel (KW of the 3 units are equal but the current of G3 is more higher than G1&G2) I think there are circulating current in Genset 3 and when the load transfer to main supply reverse power alarm appear on G3 please advice me the reasons of this problem may be result to reversed polarity of droop kit please confirm
atef
Good Answers: 445
Re: ATEF
06/12/2011 7:03 PM
You have posted this 3 times in the past month, and have ignored the responses and/or not responded to most requests for more information. It is time for you to search CR4 for previous answers to similar questions, to learn how these systems work, or pay someone to do your work for you.
Re: ATEF
06/13/2011 8:36 AM
As you have been told, this is a repetitive question!
You did not respond before on request for more info or to do certain test/data gathering (by the way 'together' not 'to gather' in your text!!).
In any case, for what it is worth: kW and currents are not enough info to help you. You need the full picture for each unit: kVA, kVAR, kW and the currents, and also, the power factor viewed by each unit.
G3 current could be higher than the others while its kW is the same because the p.f. is different (which means the kVA is different). When you go back to the main supply, releaving all the gensets from their loads and still in paralllel, the whole picture will change since the reactive power required by the load has suddenly been removed. Therefore, depending on the position of the excitation status just before the changeover, there will be some stabilising backflow or forward flow of current between the 3 units. Thus a probability of reverse flow into G3 in this case (?).
Take it from here...
Re: ATEF
06/13/2011 9:55 AM
Two things are obvious here.
1. You have no understanding of the problem at hand, or the solution.
2. This forum is incapable of infusing you with un-possessed knowledge you desire.
Hire a competent electrical engineer or technician to fix the problem.
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
Re: ATEF
06/21/2011 5:36 AM
Oh the answer is clear to me, I DON'T NEED ANYMORE INFORMATION.
It would be more obvious if the KW's were different, then you would need to unclog the fuel filters in G1 & G2 to fix it. Since the amps different ateeff you need to unclog the exhaust system to fix your generators. Remember the problem is ALWAYS mechanical: you don't have to fix it and maybe hurt yourself, hurt someone else or burn down the gensets.
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
Register to Reply 4 comments
kwcharlie (1); LAA_Lucke (1); lyn (1); RAMConsult (1)
