Previous in Forum: VMM (Voltage Monitor Module)   Next in Forum: About Stator Poles
Multiple Factor
06/12/2011 3:59 PM
hi friend,s,
is there anybody who can explain that what is multiple factor. how to get it in energy meter,s, in power transformer,s, in current transformer,s.
thank,s in advance.
Ikram Shehzad
Good Answers: 70
Re: multiple factor
06/12/2011 6:39 PM
Your questions have multiple answers, try clicking HERE DJ
Re: Multiple Factor
06/13/2011 11:20 AM
hi,
u must be talking about Multiplication Factor (MF) of Energy Meters. It is the factor with which one need to multiply the energy meter differential reading (Closing reading minus opening reading) to arrive at the actual energy consumption over a given period of time. This is required particularly if CTs (Current Transformers) are used to connect an energy meter. If meter manufacturer does not specify MF for his meter, the connected CT Ratio will become MF for that meter.
eg.: When a 5Amps. rated Energy Meter is connected to a circuit through use of a 100/5Amps. CT to measure the energy in a circuit that will be carrying a current upto 100Amps., 100/5=20 is the MF for that meter. So, to arrive at the actual energy consumed by the circuit over a given period of time the difference in meter readings is to be multiplied by 20.
Hope this is what your question is about.
Regards,
sitaram.
-- sitaram
Re: Multiple Factor
06/13/2011 1:17 PM
If only CT is used consider CT ratio as the multiplication factor as pointed out by Mr.Sitaram. If the energy meter pressure coil is powered by a potential transformer, then the multiplication factor will be ...
Energy meter multiplication factor = CT ratio X PT ratio
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
Re: Multiple Factor
06/17/2011 6:23 AM
I would suggest you to go to the posting http://cr4.globalspec.com/thread/36700
You will get your answers.
Vinu_Answers Sure_Answers
Sure Answers Always
Register to Reply 4 comments
dj95401 (1); pravinba (1); sitaram (1); Vinu_Answers (1)
