Hey everyone, I was thinking recently about recycled wood. Well first off, most recycled wood products aren't very good or at least aren't as good as their original. Particle board (the saw dust/powder stuff) has it's uses, but most recycled wood products aren't as strong as the original and need the use of glues and binding agents.
Wood is composed of mainly cellulose and lignin. There are processes that can separate these two products from any wood, paper or fiber source. Cellulose and lignin are used in other products but require lots of binding agents or chemical processes. Cellulose acetate is known by everyone. From buttons to film to fibers in clothing are made from it. As far as lignin goes, I have no idea what it could be used for or is used for. I couldn't find any mechanical properties of it but all I know is that wood is technically a composite of cellulose and lignin and that lignin is an important structural component of it. There are a lot of things that use wood powder, like bakelite and I'm pretty sure that "plastic lumber" for decks and outdoor structures use a recycled plastic/wood fiber composite. I'm not talking about that kind of use.
As far as I know, there aren't any composites that try to recombine cellulose and lignin into some usable material. Clearly it's an effective combination, but what could be done to duplicate it? I figure the reason is there isn't a way to bond the two materials at the molecular level in the same way that nature does in it's self organizing ways.
So I was wondering if there is any possibility of using raw recycled cellulose and lignin for an engineered biomaterial that is as good as other materials. I figure trying to make "artificial wood" would be really stupid because wood kind of grows on it's own and is quite cheap. The only beneficial aspect I was thinking of was using waste and recycled wood products (from demolished homes, yard waste, paper etc) to make something else that's good enough to be used again.
So it's just a thought and I wanted to know if there were any people with some additional insights!
Thanks!
Nick
