Previous in Forum: Vector group of a transformer   Next in Forum: hyro generator keeps trippping
10 comments
Electrical
04/14/2007 1:58 AM
What is a Real Time Power Factor Correction System?
Re: Electrical
04/14/2007 5:13 AM
Traditionally power factor correction was provided by fixed capacitor banks which were calculated to address the worst maximum demand periods, but obviously this fixed value correction could not mirror the full 24 hour cycle requirements.
Later, power factor monitoring relays switched individual capacitor banks to give closer monitoring with the relay switching capacitor banks in and out according to demand conditions.
I can only assume that Real Time Correction is a more sophisticated system which uses multiple smaller capacitor banks to mirror and keep in step with demand conditions 24 hours a day.
I'll keep an eye out for the correct answer
Re: Electrical
04/14/2007 11:34 AM
A micro processor is set up to measure the phase relation ship between the on load and supply and a refference so as to determin the powerfactor and phase shape it then trims the correction inline with the changinging load more inductance switching in more capacitance until the phase is back to the best powerfactor. It is just a fancy computor unit that can switch the caps in and out via electronic switches. Relays are too slow and they wear out. Each machine can have its own unit built in. It saves on power disturbances.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Re: Electrical
04/14/2007 1:32 PM
I did not understand what you meant by the line at the bottom "There are the ____"would u clarify Pl ?
Re: Electrical
04/14/2007 2:22 PM
What my tag line "There are them that knows and them that thinks they knows."
It means much what it says "some know more than others" "Some just think they know" (Which are you?) as in do you know all you think you do? May give an opinion but have no knowledge others give information without knowing what they type. One person admitted to going to wikipedia and just taking his answer from their and google he gave the right answer but said he knew very little of what it meant.
Re: Electrical
04/16/2007 1:42 AM
Hi !
I am sorry but you need to correct the language you have written,it has to be
There are them, who know and them, who think they know.
I guess this would be a proper one.
I also do not understand the propriety of this question as i tried getting information which i did not have.
PsD
Re: Electrical
04/17/2007 3:53 PM
No it's just fine I have a degree in english I am being ironic.
Re: Electrical
04/18/2007 2:07 AM
Hi
In that case i apologize for correcting you. anyways i am still unaware of what RTPFC is.
Re: Electrical
04/18/2007 6:35 AM
"I'm not as drunk as some thinkle peep."
India - Member - New Member
Re: Electrical
04/17/2007 10:54 PM
We do get real time compensation for both Reactive & Harmonics now adays. The Circuit consisits of IGBTs and a capacitor.The capacitors will charge & discharge depending on reactive compensation require. The regular Passive filters ( tank circuit)just connected to circuit without change in any compensation depending on system conditions.
Nothing is impossible, Impossible is nothing
Re: Electrical
04/18/2007 2:11 AM
Pl. convey who does this using IGBTs and how reliable it is.
What is the switching time in that case?
Pl.pass on the details.
Register to Reply 10 comments
Anonymous Poster (5); BrainWave (3); hara143 (1); PWSlack (1)
