Previous in Forum: Failure of Coil   Next in Forum: UL94 flamability Rating Question
Thrust Washer
06/14/2011 8:47 AM
What kind of material need to use for thrust washer.
Application is vertical load and it is rotating parts.
Re: Thrust Washer
06/14/2011 9:14 AM
<...rotating parts...>
Doesn't that make the thing a "thrust bearing"?
Re: Thrust Washer
06/14/2011 10:38 AM
Washer, bearing who cares.
You need to start with the basics as your question indicates that you are devoid of all knowledge of the subject.
Know your thrust bearings | Machine Design
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Re: Thrust Washer
06/17/2011 3:57 PM
Why does the word "cantankerous" come to mind?...
Re: Thrust Washer
06/18/2011 5:11 AM
What is this thrust washer for and what type of motion it is facing. You have to give all details to get expert's opinion. I am sure no body can understand the requirement by the quiry you have put. If you really wants to enjoy the participation, come up with all the details which are available.
Register to Reply 4 comments
lyn (1); Mukesh0861 (1); Out of Box Experience (1); PWSlack (1)
