Hi: The answer is anode cathode size /laser discharge voltage/plasma discharge current/ cathode design/plasma discharge length/ gas pressure and amount of gas in the reservoir. the correct amount of he-n2 and co2..Happy 10.6 microns Mr x
You'll have to forgive Mr. X, we try to keep him in his cage, but from time-to-time he escapes and heads right for the keyboard! "Bad Mr. X! Bad! Get back in your cage!!!"
Anyway, a simple guess would be:
1. How much power are they trying to get out of particular tube design.
2. If they're getting lots of power out, are the tube's components (anode, cathode, gas supply, etc.) designed appropriately for the power levels.
3. I'd also look at the predominant wavelength they're producing. I would assume that this would be a factor. I believe there's a ~2000nm frequency and a higher ~1064nm frequency. The higher the frequency, the harder it might be on the tube.
Also, you might want to try Wikipedia. Hope some of this helps.
Anyway, I try to understand the CO2 100W laser tubes issue.
If the dimentions of CO2 100W tube has 1000 hours and other is the same but has 10000 hours life span, so I would like to understand where are the differences.
See my previous posting. I have a 40 Watt CO2 laser tube. It's a nice piece of glass work. God knows, I don't have the steady hands or patience that it would take to make one like this.
However, just like anything else you buy (a car, light bulbs, a radio, etc.) you can use cheap parts that won't last long or you can use better, more expensive, parts that will last a lot longer. And if you really want something well built, you can over engineer it beyond anything it will ever have to go through.
Remember there's hot, excited gas and plasma in the tube while it's running. So ask yourself what you think are the parts that are going to wear out first. Possibly the cathode, the anode, and the gas within the tube. I don't think the glass tube will wear out, unless, of course, you don't cool it properly.
If I were you, I'd ask these companies (I'm assuming you know them) how are their cathodes and anodes constructed. How thick are they? What type of material is used? Does the tube contain a built-in water jacket? How much supply power are they pumping through the tube? Is it a DC or RF current? Or, just straight out ask the 10,000 hour company how they get that much life out of their tubes. That's what email is for.
Mr. Vermin, reason why I read, you must work with laser.
They give me an argon laser, by factory replacement, [(Max 150mW CW 450-515nm – Class IIIb, the Standard to which the product was classified EN60825-1:1994/A11:1996) Model Number GLG3078 – Rating: 24Vdc,0.3A - 3Vdc,13A - 70-100Vdc,9.1A / Manufactured:June,2003]-(the timer mark 13873 8 hours to 1/10 the last number).
I have never worked with laser, the operational manual it says 10,000 hours to use, "The question?" = - "Think that it is worth the trouble to repair power light?" – "I not, what idea has application could give him, I would use it like experimenting, my new toy" - According the report it works, but to lowered its power - also I have the source, it's ok, Model number GLS3078 with CN4 connector 25 pines, to control the source, you know how connected?. I don't see the service manual, it is my following step, by rough estimate of good technician, whatever you consider the cost, if it is worth the trouble, or I can use it as this estate.
I thank to you, if you want something of biosecurity I help you. I have an electronic laboratory something equipped.
I show diagram to you of the laser.
We must understand the things like are and not to try that they are as we want.
GT, let me see if I can figure out your question... It sounds as though someone gave you an ion laser to play (work?) with. If yes, a couple of warnings:
1. The power supplies for these things put out fatal voltage, so watch it. Even after they're shutdown and unplugged, the voltage has a tendency to hang around for awhile!
2. The pin-outs for the connection between the laser head and the power supply are complicated. There's a round, multi-pinned connector on one type and a square, multi-pinned connector on the other. I wouldn't go poking around either of these connectors with a Volt meter or oscilloscope probe. Doing so is looking for things to go BANG!!!
3. Be careful of the laser tube in the laser head. While on, these things run very hot, and have lots of nasty voltage.
4. If you break the tube, hold your breath and get the heck outta there. There's some nasty chemicals inside these ion laser tubes.
My best advice is if you have an ion laser, unless it's a complete system with a working head and the correct corresponding and working power supply. I wouldn't try messing with it. It's just too risky unless you're familiar with the system.
Hope this helps. Let me know.
You said that you bought a power supply--is the power supply specifically designed for an ion laser tube? Do you have the correct cable for connecting the laser to the power supply? Usually, there's another device that plugs into the power supply, it's a control box that allows you to control both the voltage and current going to the laser?
As far as building a power supply from scratch... I wouldn't touch that with a ten foot pole!
Anyway, answer the questions above, and I'll see what else I can tell you.
OK. These argon lasers come in two formats... A box with a fan on top (looks like this is the kind you have), and a cylinder, where the fan goes in back. In both of these formats, the cable comes from the laser head and plugs into the power supply.
In the picture, you're holding the plug that should connect to the power supply. So, does your power supply have a corresponding receptacle?
I just got message this morning that the e-bay seller of the JDSU has refunded my payment and said that the PSU has been misplaced...
So I guess I need to find a PSU of some sort that can be adapted...
About your question. I do have many other lasers. But this is my first argon laser. It is a project. (I like projects) I have many laser projects shown here:
I have laser experience yes, but not with argon's. From what I understand, the PSU for an argon is very complex. And it must be configured to control the filiment, the fan, as well as the laser itself...
Yeah, but those types of lasers were made by the millions. Here are two places I frequently search on eBay for laser stuff. Perhaps you can find a power supply...
