Previous in Forum: Hydropower   Next in Forum: Condensation Issue
Impact Load, En 19 Shaft, Through Hardened, Case Hardened
06/18/2011 8:17 AM
We wanted to compare impact load in jule for En19 bar for
Through hardned (50 HRC) vs case hardened (550 HV - nitriding).
and what should be the hardness of bar before nitriding
Re: Impact load , En 19 shaft , through hardened , Case hardened
06/18/2011 8:26 AM
Anonymous Poster #2
Re: Impact load , En 19 Shaft , Through Hardened , Case Hardened
06/18/2011 10:07 AM
Look for the hardness in the standard in normalised condition (usually) or Hardened and tempered condition
Did you consider EN40B or EN41 too (they are good nitriding alloys with quite high core strength)
06/18/2011 1:23 PM
This question sound like it should be in the Mechanical Engineering section. Check on the left of the screen for ME.
Register to Reply 3 comments
You might be interested in: Bar Code Software, Case Equipment, Bar Code Cards
