Previous in Forum: Valve Rotators   Next in Forum: Impact Load, En 19 Shaft, Through Hardened, Case Hardened
Hydropower
06/18/2011 5:38 AM
Hi to all. Can any one please explain me more abt hydro turbines and ther uses
Anonymous Poster #2
Re: Hydropower
06/18/2011 7:43 AM
abt
(I don't know)
Hydro
\Hy"dro-\, Hydr- \Hy"dr-\
http://www.dictionary.net/hydro
1. A combining form from Gr. ?, ?, water (see Hydra). [1913 Webster]
2. (Chem.) A combining form of hydrogen, indicating hydrogen as an ingredient, as hydrochloric; or a reduction product obtained by hydrogen, as hydroquinone. [1913 Webster
http://www.merriam-webster.com/dictionary/turbine
tur·bine
noun \ˈtər-bən, -ˌbīn\
Definition of TURBINE
a rotary engine actuated by the reaction or impulse or both of a current of fluid (as water, steam, or air) subject to pressure and usually made with a series of curved vanes on a central rotating spindle
Uses - to convert the hydraulic head into kinetic (rotary) energy.
Re: Hydropower
06/18/2011 9:48 AM
I think you should start by looking for "hydraulic turbines" or "hydroelectric" on Wikipedia and read that / those articles. If you have specific questions after that, come back and ask them.
If you don't know how to find articles like that, either using the search box on Wikipedia, or using google, come back and ask about that.
Re: Hydropower
06/18/2011 1:38 PM
right now im working in hydropower sector but i need more knowledge what wiki or giigle gives so can u ppl help
Good Answers: 62
Re: Hydropower
06/18/2011 3:15 PM
Well, if you are going to get a name and hang around; least we can do is help.
Hydro turbines are one of the oldest forms of energy extraction and have had long history of improvements.
Originally designed to generate mechanical energy for use 'on-site' in applications like milling, weaving, and machining; modern hydro turbines are used almost exclusively for mechanical to electrical conversion so the resultant energy can be transported to the site of use.
How am I doing?
Re: Hydropower
06/18/2011 9:22 PM
Emmit has given you some basics.
Go here, then come back with questions.
The History of Hydropower - personal.psu.edu
Re: Hydropower
06/19/2011 2:53 AM
you should just Google for a straight forward answer to your question !
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Re: Hydropower
06/19/2011 7:54 PM
Google is the best way to get answers for your homework.
Reply Score 1 for Off Topic
Anonymous Poster (1); Badboyimmortal (1); bravo88 (1); edignan (1); lyn (1); rhkramer (1); StandardsGuy (1)
