Previous in Forum: power supply   Next in Forum: Internal resistance of Battery charger
PLC Siemens CPUs
04/15/2007 12:20 AM
Dear Friend how can I get the password from Siemens PLC CPU (s7-300-2DP-318)
and CPU S7-400-146 2DP.The problem is the plc protected by the password and I can not get the program.Who can help me for that
Pathfinder Tags: PLC siemens
United States - Member - USA Engineering Fields - Control Engineering - Never enough money
Re: PLC Siemens CPUs
04/15/2007 9:33 AM
Siemens S7 manual See page 20.
04/15/2007 9:53 AM
Dear Friend the problem is that I need to Upload the program from the CPU to my PG but I can not because of the CPU is protected by password
04/15/2007 11:40 AM
The next thing I would do is try to track down the last person to have full access to the PLC. I'm guessing you already tried this but I had to say it anyways. The next possibility is to clear the CPU but only if the program was saved to the EPROM or non-volitile memory. Once the CPU is cleared, powered down and then restarted the password protection should be cleared according to the "FAQ" at the Siemens website and the program should reload from the EPROM.
Siemens FAQ for "reset access"
Often Programmers that feel the need to install passwords on customer systems will use the companies name or initials. When I first started working for my current company everything was password protected with 'USF', so try a few combinations of your companies name or any common passwords that might be in use elsewhere.
As general rule, unless there is a specific requirement to password a PLC.... Don't. If the use of passwords is required then make sure a copy of the password is kept in a firesafe.
04/16/2007 5:16 AM
saearch this website http://www.plctalk.net/qanda/ and you may find some clues on how to get in through a backdoor. Or contact your local Siemens office.
Register to Reply 4 comments
Anonymous Poster (1); jstolaruk (1); Richard L (2)
You might be interested in: CPU Cards and Modules, CPU Chips, CPU Fans and Coolers
