Previous in Forum: Pls Explian BDV TEST of transformer oil   Next in Forum: Disc insulator
LA rating
06/22/2011 2:10 AM
in 220kv switch yard why we are using 198kv LA?
like same for 400 kv why we are using 360 kv LA?
Re: LA rating
06/22/2011 2:14 AM
There must be a factor of 0.9 involved.
Re: LA rating
06/22/2011 2:35 AM
yea that we know. why should use 0.9 factor?
Good Answers: 170
Re: LA rating
06/22/2011 9:58 AM
The LA Rating is selected on the formula:
Highest System Voltage (HSV) / Co-efficient of Earthing (Ground Fault Factor)
At EHV Levels, like 220kV & 400kV, the system will be solidly earthed and for solid earthing, the co-efficient of earthing is 0.8.
So, for 220kV Nominal System Voltage the HSV is 245kV. And, the LA rating will be: 245 x 0.8 = 196kV. The nearest standard LA available in the market is 198kV.
Similarly, for 400kV, the HSV is 420kV; and, the LA rating will be: 420 x 0.8 = 336kV; the nearest standard LA available in the market is 360kV.
Register to Reply 3 comments
electricalexpert65 (1); prabhurak (1); Tornado (1)
