Previous in Forum: Filter System for Irrigation   Next in Forum: Restoring a 1920s Koken Barber Chair
Expansion Joint
06/23/2011 5:54 PM
i notce there is expansion joint for the pipe crossing the expansion joint concrete
could any one tell me the reason
regards
m-a
Re: Expansion Joint
06/23/2011 8:44 PM
Could you try again? Expansion joints are supposed to control cracking of concrete.
"pipe crossing"?
Re: Expansion Joint
06/23/2011 9:42 PM
If the concrete next to its expansion joint moves, then maybe the pipe should also move to match....
Re: Expansion Joint
06/23/2011 11:42 PM
Yes, if the concrete expansion joint separates, the pipe will have to move with one side or the other, hopefully.
Re: Expansion Joint
06/24/2011 2:29 PM
thanks a lot
how can the pipe move and its free span- i mean the pipe not fixed with the concrete
only the support move or there is something else
thanks
m-a
Re: Expansion Joint
06/24/2011 2:32 PM
yes pipe through
lyn (2); mohamed amin (2); Tornado (1)
