Previous in Forum: Internal resistance of Battery charger   Next in Forum: Multimeter Reading Question
Torque
04/15/2007 5:55 AM
How to calculate DC motor Torque? Is it same for AC motors also?
Pathfinder Tags: AC DC torque
Re: Torque
04/16/2007 2:08 AM
Torque = number of poles x number of winding x max flux x I/ ( 2 x 3.14 )
Re: Torque
04/16/2007 2:27 AM
T=(no.of poles *no.of conductors*max. flux*1.59*armature current)/no.of windings
no the calculations for the dc and ac motor torques are not same
regards
priyanka
Good Answers: 16
Re: Torque
04/16/2007 2:45 AM
So which one is AC and which is DC. Please keep it simple for us poor mechanically minded individuals.
Make it so.
Re: Torque
04/16/2007 4:11 AM
Thank you for the answer. I am one formula now. Please tell us is it okay.
i.e Torque in Kg-m=(Motor HP x 727)/Base Speed.
Re: Torque
04/16/2007 5:10 AM
Contacting the original manufacturer of the motor with a serial number may yield a motor performance chart that will indicate torque, speed, current, efficiency, etc., etc.
Good Answers: 137
Re: Torque
04/16/2007 6:34 AM
Assuming you want rated torque, torque in N.m = rated power (watt)/rated speed (radians/sec). Same for AC and DC.
Codey
Good Answers: 42
Re: Torque
04/16/2007 3:19 PM
For US units of HP, RPM, FtLbs:
Torque = HP x 5250 / rated speed
Same for AC or DC, it is in the definition of torque / power / work / speed which are all physics. Motor name plate only reflects mechanical power produced.
Now, if you want to calculate accelerating torque, methods of starting, efficiency, inrush current etc. that is a study in itself.
Register to Reply 7 comments
Anonymous Poster (2); BlueAussieBoy (1); Codemaster (1); GW (1); Prasanna venkatesh (1); PWSlack (1)
