Previous in Forum: Generator   Next in Forum: High Voltage Switching Procedures
IPS Aluminium Tubing OS Substations
06/25/2011 7:16 AM
For our 80 MVA , 132 /11 kV substation(out door) we are planning to use IPS aluminium tubes .I would like to refer some web sites for viewing the photographs of such substations to have an idea about terminal connections of CT,PT,LA ,ISolators and post insulators with IPS ALU tubes.Can any one give details about related web sites.
T.Sriram
Good Answers: 181
Re: IPS Aluminium Tubing OS Substations
06/26/2011 7:25 AM
Not without looking on Google, which is what I suggest you do.
Or contact the equipment manufactures, they will help if you're actually buying the equipment.
Good Answers: 131
06/27/2011 10:57 AM
Connections from tubular bus to electrical apparatus are usually made with cable jumpers to account for expansion and contraction of the tube's length due to heating and cooling. Occasionally they are made with expansion connectors (if it's an in-line connection), and some connections can be made with a solid (no flex or expansion) connector if there is flexibility in the apparatus. Take a look at the site for DMC Power, which makes one variety of connectors for tubular bus. Theirs are mechanically swaged onto the tubing, but it is also possible to use bolt-on compression connectors or welded connectors. There are some good examples in their photo gallery.
http://www.dmcpower.com/connectors/substation-bus.html
http://www.dmcpower.com/resources/photos.html
An overall good reference for substaiton design is the free download "Design Guide for Rural Substations," available here:
http://www.usda.gov/rus/electric/pubs/1724e300/1724e300.pdf
Register to Reply 2 comments
