Previous in Forum: 2mm Drill Bit Broke in 20dia SS Rod   Next in Forum: US Supreme Court Curtails Suits Over Co2 Emission
What is This Plumbing Item?
06/25/2011 10:03 AM
Screwed into the 3/4" FPT hot water outlet of a 40 gal water heater is a white plastic (PVC?) insert that has a cross in the center. It does not restrict air or water movement. What is this device? It appears the top part is gone. Is it the remnants of a check valve, whose ball is gone? If so, what is its intended purpose? To shut off flow if the downstream piping is broken?
If this item broke, could water be released into the room containing the heater? Or is it totally contained in the metal piping?
Good Answers: 137
Re: What is this plumbing item?
06/25/2011 10:16 AM
The cross in the centre makes it sound like a vortex breaker.
06/25/2011 11:37 AM
I have since removed it from the tank. It appears to be a plastic isolation piece, firmly attached to the inside of a special steel male nipple which is screwed into the tank's projecting female nipple, with a 3/4" od x 32" solid sacrificial anode firmly attached to the plastic piece.
The plastic piece has a horizontal tunnel above the anode(?) that allows the hot water to enter and travel upwards thru the plastic piece. The cross I referred to earlier is actually just an integral plastic bar.
So right now I'm concluding its just an easy, economical way to install an isolated anode.
Re: What is This Plumbing Item?
06/25/2011 11:20 AM
Good Answers: 176
06/25/2011 11:50 AM
Does it look like this?
3/4 in. x 3/4 in. Steel and Plastic MNPT x MNPT Dielectric Water Heater Heat Trap features inert thermoplastic linings to help prevent lime and scale buildup.
- Helps prevents galvanic local cell corrosion
- Steel construction with inert thermoplastic lining to help prevent lime and scale buildup
06/25/2011 2:46 PM
Good morning Iris,
No, I have since removed it. It is a neat invention to allow the insertion of an isolated anode in the same nipple the hot water exits the tank, without having to weld on a nipple just for the anode.
I saw some down at the hardware store this am.
06/25/2011 11:19 PM
Hi Flyinghigh,
it could be a pressure relief valve. try to google if it looks the same. usually most of the domestic hot water tank fitted with pressure relief valve and air breaker/release. However as what the nearest guess as you said "has a cross in the center" could be the pressure relief valve".
You should asked the hardware when you saw it this morning as you said.
Roman
Register to Reply 6 comments
Codemaster (1); flyinghigh (2); Fredski (1); Iris (1); Roman (1)
You might be interested in: Water Heaters, Piping Services, Piping Systems
