Previous in Forum: McAfee Problem   Next in Forum: How to Find Loss Factors in Ansys Workbench Using Modal Analysis
9 comments
RSlogix
06/26/2011 8:10 AM
Hi All,
AB have few application software, please advise if RSlogix5, 500, 5000 is all the same application or different?
Regards
Good Answers: 54
Re: RSlogix
06/26/2011 10:55 PM
All different, there are also many, many different versions, each one more expensive than the last. Plus you'll need a "service" agreement because its so convoluted.
Stay away from RS if you can.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Re: RSlogix
06/26/2011 11:28 PM
"Stay away from RS if you can".... Can you if you have AB PLC???
Good Answers: 54
Re: RSlogix
06/27/2011 12:29 AM
That does make it more difficult.
It may be cheaper to replace the PLC rather than buy the software.
Good Answers: 54
Re: RSlogix
06/27/2011 2:24 AM
I like OMRON stuff myself, especially for stand alone applications. It's cheap, all the different components are integrated with each other and it's powerful.
Good Answers: 42
Re: RSlogix
06/27/2011 12:28 AM
We joke you only get to rent Rockwell Software.
The ControlLogix platform is incredibly powerful, but the programming environment is convoluted. It requires RSLogix 5000 sw, with 21 flavours. If Rockwell programs it they ensure only their trained service technician can understand it. They seem to have forgotten about simple ladder logic and abuse or ignore the power of function block programming.
OK, I am ranting.
Re: RSlogix
06/27/2011 1:31 AM
With only 2 machines here using AB PLC - and no experienced technicians around - it makes very much sense to me to switch to another brand of PLC. Thanks for the suggestion. Especially as we will never use the 'incredible powerful features' of ControlLogix (we don't even have an idea about what these features are....:-))..hahhaha). If we call RSLogic similar to Microsoft Windows, is there something available which is really 'generic' - call it 'Linux'? And will it be possible to convert current program to new software?
Thanks a lot for any input on this!
Re: RSlogix
06/27/2011 6:31 AM
wow! Feel the hate. LOL I guess I'm wierd because I find the Rockwell software some of the easier PLC software to use and I have had to use a bunch (AB, Siemens, Omron, Panasonic, Mitsubishi, Automation Direct). I don't argue that it's very expensive and tech support agreements are outrageous but so are some of the others.
To add something useful to this thread:
PLC5 - RSLogix 5
SLC500, Micrologix - RSLogix 500
ControlLogix, CompactLogix - RSLogix 5000
Also I believe they offer a maintenance version of the software where you can look at the logic and make small changes but it doesn't allow you to do "larger" changes such as add subroutines or tasks. The intent is for plant maintenance personnel, maybe this would be enough for you.
Shawn
Re: RSlogix
06/27/2011 8:22 AM
Hi Shawn,
I have used a couple of different Ladder Logic programs. The RSLogix was, as I recall, rather cumbersome - loads of functionality, most of which you will never use.
My favorite was HornerAPGs CScape that is free and very easy to use.
You did add something useful to this thread, so GA.
Good Answers: 18
Re: RSlogix
06/27/2011 10:57 AM
GA from me also. Your post is the only one here that actually answers the OP's question.
I also agree with you that the programming interface for RSLogix is about as easy as it can be. I can troubleshoot, navigate, and edit programs with RSLogix far more quickly and easily than with GE-Fanuc, Automation Direct, or Siemens. I'll add that AB has taken a bit of a lead in moving away from serial interfaces. Especially with their MicroLogix PLCs that can be purchased with an EtherNet Port for under $1000US. Forward thinking designers should not underestimate the significance of this.
On the downside, the expensive support contract makes you feel like you have to purchase the software again every year.
The most valuable of all talents is that of never using two words when one will do. ~Thomas Jefferson
EElectrician (1); ffej (3); GW (1); mdquay (2); Mikerho (1); Shawn33 (1)
