Hi all,I am in the dark on what is happening now to my boiler.After almost 3 years in operation,we encountered frequent water tube leaking,front wall at welding joint,boiler bank(not welding joint).I wonder if anyone can tell if all the tube are of correct specification eg.if Sche 40 is ok for 40 barg.Or is there any test to be carried out to determine the suitability of tube for a particular application?I am of the view,based on visual inspection on the removed portion,it is not caused by water treatment problem as ph never below 8.
