Previous in Forum: MAWP (Max. Allowable Working Pressure)   Next in Forum: Hydro Static Test Pressure for Accumulators
Which Formula Can I Use?
06/27/2011 3:57 AM
Hallo,
Can anybody tell me or give some referance to Which formula I can use to calculate lining wall thk. of PP for PP lined equal tee pipe fitting.Where the Tee in line with 700mm/hg. vacuum for 8 hrs. minimum.
Thank in advance for your valuable support and help.
Re: Which Farmula can use
06/27/2011 4:07 AM
Commercial pipe and suitable fittings are rated by the manufacturer for a range of duties and temperatures. One simply looks up the required information in tables. Calcuation is therefore not required.
06/27/2011 6:37 AM
Agreed,
But For betterment of design and knowlage it is required. And also it will help to avoid dependibility on manufacturer.
Thanks
06/27/2011 8:03 AM
<...avoid dependibility on manufacturer...>
OK, so where is this new manufacturing plant to be set up?
Register to Reply 3 comments
