Previous in Forum: What Kind of Things Do I Need to Know When I'm Learning the Fabric or Textile?   Next in Forum: Sewing machine problem
small force sensors
06/28/2011 1:02 AM
I'm looking for a (thin 1-2 mm) sensor to measure forces over time. I have contacted many Piezo manufacturers but most are currently working on gas sensors. Does anyone know of a manufacturer of such a device?
Thanks!
No matter where you go, there you are.
Pathfinder Tags: piezo
Re: small force sensors
06/28/2011 2:04 AM
Searching on "load cells" or "strain gauges" might work. (I don't think piezo is quite the right concept.)
Good Answers: 183
06/28/2011 2:51 AM
Describe better your application as force magnitude, uncertainty level and available space. If you come within some limits it is possible to suggest even 0.5 mm sensors. If for you piezo is a quartz sensor (or similar) then it is totally not usable since it is operational ONLY with high dynamic loads. This is related to the physics of "piezo" electricity. If you think "piezo" resistive sensor they can be used for low dynamics as well.
06/28/2011 6:05 AM
Thanks for the comments and redirection. I'm looking for multiple force sensors that one could apply to the palm of the hand (or glove) or insert in shoes to measure forces applied while lifting weight OR while running. As well, small enough and wide enough to measure the impact applied acros a shoulder pad or a knee pad in a sporting event.
Good Answers: 183
06/28/2011 10:06 AM
Look at TEKSCAN they have a sensor exactly for what you want to do it is a thin shhet sensor FLEXIFORCE.
08/29/2011 5:18 PM
This may be a little late in the game, but you may also want to try some FSR sensors. Interlink makes those and I think you can find them on DigiKey for cheap.
nick name (2); techjeff (1); Tornado (1); vett66rob (1)
