Previous in Forum: Labeling Electrical   Next in Forum: How Can I Find/Build a "Tool" to Reverse E-Polarity in a Controlled Fashion?
fuel cost low
06/28/2011 12:10 PM
Hi all Engineer
ask about
how can reduce of fuel for Generator
in plant power station
thanks
Re: fuel cost low
06/28/2011 12:19 PM
Increase efficiency.
More info would be more helpful. Type/size of generator...
The early bird may get the worm, but the second mouse get's the cheese.
Re: fuel cost low
06/28/2011 2:06 PM
Dcpppf is correct, one option to decrease fuel usage is increasing efficiency.
Other options include:
decrease output
increase idle/ down time
creative accounting, perhaps you could securitize the less full tanks and then group the empty portion of the securitizations into collateralized tank obligations (CTO) which you could sell to investors who will be confident that the FED will bail them out once the ponzi scheme implodes.
Re: fuel cost low
06/28/2011 2:37 PM
Switch to a different type or cheaper source of fuel (note some generator modification may be required).
Re: fuel cost low
06/29/2011 4:09 AM
1. Turn it off when it is not needed.
2. Make sure it is loaded to its best efficiency point, if possible. This point will be stated by the manufacturer.
dcpppf (1); jack of all trades (1); PWSlack (1); truth is not a compromise (1)
You might be interested in: Fuel Cells, Fuel Testers
