Previous in Forum: Hoist Motor & Electrical Protection   Next in Forum: Ferranti High Voltage Test Equipment
difference between CVT & IVT
06/28/2011 2:02 PM
in big generating power station's switch yard CVT & IVT use for protection and measuring voltage.one is capacitive and one is inductive voltage transformer. So i want to know what is difference between this. Can only one (either CVT or IVT) use in each phase.
Curiosity made genius
Good Answers: 131
Re: difference between CVT & IVT
06/28/2011 2:15 PM
Use your Google search to find detailed info on Capacitive Voltage Transformer (CVT) vs. Inductive Voltage Transformer (IVT). That will tell you in detail the differences of each.
As the names imply, CVTs are built on the basis of a capacitor voltage divider (tapped stack of capacitors) to get a low voltage for protection and metering off a high voltage primary. The final section of the capacitor feeds a small VT that gives the output, with some phase correction circuitry. CVTs are fine if you are using modern digital relays and meters, because they have relatively low burdens. The CVT has limited VA capacity to drive them, so they often cannot provide what's needed to reliably operate older electromechanical relays and meters.
An IVT is basically a regular wound (hence "inductive") transformer, and produces its secondary voltage due to the ratio of primary to secondary winding turns. They are often capable of higher VA, so they can work with the burden of electromechanical relays, or if they are used in a bus metering & protection scheme where there may be relays, lights, meters, etc. all connected to one set of VTs.
Hope this helps.
06/28/2011 2:40 PM
thanking u. Its little but effective
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
06/29/2011 4:14 AM
You can employ either CVTs or IVTs for the accurate and wise measurement and protection of 3-phase system. But, If you want to take trail and check result, you can employ one CVT and one IVT in each phase.
Capacitive Voltage Transformer:
A voltage transformer comprising a capacitor divider unit and an electromagnetic unit so designed and interconnected that the secondary voltage of the electromagnetic unit is substantially proportional to and in phase with the primary voltage applied to the capacitor divider unit.
Inductive Voltage Transformer:
It is like a regular electrical Voltage transformer where two inductor`s windings are place in close proximity to each other. A voltage can then be applied across the windings of one of the inductors which will induce a current into the winding of the other inductor. The current through the winding of the other inductor will cause a Voltage to be developed across the impedance of it`s winding.
Vinu_answers Sure_answers
Sure Answers Always
Register to Reply 3 comments
PeterT (1); Vinu_Answers (1); yk (1)
