Previous in Forum: ground   Next in Forum: Poorly Designed Appliances
General Description Of Hydrogen Cooling - 1. Introduction
06/30/2011 5:43 PM
The hydrogen-cooled machines is fundamentally different from the air-cooled machine in that hydrogen is filled into its ventilating system which is gas-tight and completely shout off from the outside. The gas is re-circulated in the machine by means of an internal blower, transferring the heat in the machine to the cooling water by means of the gas cooler, then passes again through the internal blower, making from 30 to 40 re-circulation per minute. Although the gas-cooled synchronous condenser can make it possible to have the bearing and all other parts completely enclosed in the gas housing, the turbine generator whose shaft pierces through the gas-tight housing to the outside makes it necessary to provide liquid sealing glands around the shaft so as to prevent the gas leakage.
A hydrogen-cooled machines makes it possible to increase the generator's rated output by increasing the hydrogen gas pressure, furthermore, owing to improvements made on rotor shaft material and on various components, there has been a gradual increase in maximum practical rating.
synchronous.generator@gmail.com
Re: General Description Of Hydrogen Cooling - 1. Introduction
07/01/2011 12:14 AM
From this description, I am not able to see any advantages.
Good Answers: 181
07/01/2011 2:32 AM
I take it your trying to sell gas tight seals?
India - Member - New Member
Good Answers: 164
07/01/2011 4:20 AM
This is Part 1. Implying that more are on the way.
There is no question that needs to be answered, so is this your way of teaching people ? If so, wonderful ! Keep it up. Not my subject, so pardon me for not reading the next parts.
If you are trying to sell something here, please post in the commercial space.
Good Answers: 183
07/01/2011 4:35 AM
You know, some machines are water cooled and it is much more efficient since water has a much higher convection coefficient than any gas. The power density obtained is impressive. Hydrogen has also the disadvantage to be a risk for the environment if there is a leak and a heat source hot enough since oxygen is on earth almost everywhere. As for the seals a very good solution is the magnetic fluid seal which is up to a pressure totally tight if the fluid does not absorb or react with the gas.
Register to Reply 4 comments
kvsridhar (1); nick name (1); TonyS (1); Tornado (1)
