Previous in Forum: Looking for tinted glass   Next in Forum: Welding Procedure of p-91
Test Dry 12V Battery Capacity
07/01/2011 11:11 AM
Sir how i test dry battery 12v 5ah capacity weather is it healthy or not
Re: electrical
07/01/2011 11:20 AM
Connect it to a load and see what happens.
Re: electrical
07/01/2011 11:38 AM
Dear But there is a battery rack having 32 batteries and i want to know how i check a faulty battery or weak battery.
Good Answers: 53
Re: electrical
07/01/2011 12:04 PM
Charge all batteries to same level, or up to maximum possible level, and after that join them in series and connect output (12x32v= 384V) to A Load of 1 Amp (384 watt) and check the voltages on each battery, at start, after an hour and after 2 Hours, faulty batteries will show lower voltages and good one will stay up even after two hour,
Re: electrical
07/01/2011 12:20 PM
Can i check the batteries (12V,5AH) by using multimeter or any other quick method. Thanks
Good Answers: 53
Re: electrical
07/01/2011 12:26 PM
No,
Or,
You can put it under electron microscope, or on a sophisticated weighing scale and see which one have more electrons in it,
Good Answers: 181
Re: electrical
07/04/2011 6:02 AM
Re: electrical
07/04/2011 8:20 AM
Ah, so now it's a possible one dud battery in a bank of 32? OK.
  • Monitor the performance of the battery bank over time.
  • Carry out equipment-exchange planned maintenance on the batteries using a range of good spares.
  • Individually test each removed battery for performance against a set of criteria, and pass/fail the battery against that test result.
  • Renew failed batteries.
  • Place passed batteries and new batteries into the equipment-exchange spares stock.
Register to Reply 7 comments
masood (2); PWSlack (2); rakesh_semwal (2); TonyS (1)
