Previous in Forum: Air Flow Question.   Next in Forum: Material of Construction
Pellet Plant Roller Worn Out In Less Than 250 Hrs Of Running
07/02/2011 4:43 AM
we are running a pellet plant of 5 t/h capacity. the rollers of the pellet mill getting worn out in less than 250 hrs of running. and after this we cannot use the same roller as the working height of the roller is 15mm. the rollers goes in scrap. can anyone suggest how to reuse the rollers so that maint cost can go down.???
Re: pellet plant roller worn out in less than 250 hrs of running
07/02/2011 4:47 AM
What are they made of? Any hardness numbers?
07/02/2011 8:40 AM
i have sent the piece of it for the material specification. And hardness number. I will send you some photos of it by tomorrow morning. Thanks for reply
Good Answers: 38
07/02/2011 9:35 AM
Pellet rollers are basically food industry machines....useful only if you are making pellets for something like dogfood.
Due to the fundamental nature of thier action, they are subject to wear if not perfectly aligned or if an abrasive material ( ohh...say coal dust) is attempeted to be pelletized.
Since you bought you machinery from a sleazeball used-equipment broker and since you did no alignment and have no records, what exactly did you expect ?
What is the nature of the material being pelletized ? Is it abrasive ?
Do the machines fail because of your neglect of alignment or are you running an abrasive slurry through them ?
Re: Pellet Plant Roller Worn Out In Less Than 250 Hrs Of Running
07/02/2011 10:15 AM
First let me know how much do they wear out I mean is it in microns or mm. And also the materials specs with its hardness.
Later then I can suggest something probably.
CNC Solution Provider
07/03/2011 3:24 AM
Castolin makes special hot spray hard wearing atomized alloy powders that can be sprayed on undersized parts to reclaim.
bioramani
07/03/2011 8:10 PM
What about machining the rollers further undersize, then sleeving them with a hardened or surface hardened tube up to the original size, then as they wear undersize you simply replace the sleeve, and the hardened sleeves should last longer anyway - obviously the sleeves, at their maximum wear point must still be thick enough to retain structural integrity.
07/08/2011 5:52 PM
There are many types of roll shells that are designed for different applications.
check out our website www.jacobscorp.com
Roll Shells
Give us a call or email with your pelleting parameters and we can find the best setup to give you the lowest cost per ton. IT is all we do, engineer wear parts to be the best.
Chad - Engineer Jacobs
bioramani (1); cplumb (1); hnetplanet (1); MJCronin (1); Tornado (1); uniq_engineers (1); WAWAUS (1)
You might be interested in: Roller Screws, Conveyor Rollers, Needle Roller Bearings
