Previous in Forum: Urgent Help 480v 60Hz Machine Needs To Be Run On 415v 50Hz   Next in Forum: About Stardelta Diagram For 3 Phase Motors
Fire Resistance Cables
07/03/2011 7:11 AM
There are any standards detect the percentage of overlap for Mica Tape for fire resistance cables?
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
Re: Fire Resistance Cables
07/04/2011 3:44 AM
It is fire resistant cables. Required standard is,
"IEC-60371-3-2 Insulating materials based on mica - Part 3:Specifications for individual materials - Sheet 2: Mica paper".
Vinu_Answers Sure_Answers
Sure Answers Always
07/05/2011 1:55 AM
You also refer to the below IEC standards for Fire Cables:IEC60332 Part 3 defines three categories ofthe volume of combustible non-metallic material present in the test before the flame is applied.
The fire resistance tests of IEC60331 impose a severeduty on the cable sample.
Register to Reply 2 comments
