Previous in Forum: Rieju RS2 Matrix 50cc   Next in Forum: Drive by Wire: Electric Steering?
Torque
07/05/2011 6:35 PM
What is the standard Torque setting for wheel lock?
Pathfinder Tags: psi torque Wheel lock
Good Answers: 123
Re: Torque
07/05/2011 7:46 PM
It is now almost twice what it was in 1967.
Any chance you could less specific?
Bob
Re: Torque
07/06/2011 5:32 AM
if you are talking about wheel locks for your your auto wheels, then if would be the same specs as the other wheel lug nuts.
Good Answers: 44
Re: Torque
07/06/2011 10:09 AM
Most passenger cars vary between 80 and 100 ft lbs. Check your owner's manual for the proper specs.
Re: Torque
07/06/2011 11:11 AM
Isn't it the weight applied to the wheel multiplied by the nominal wheel diameter divided by the coefficient of friction between the wheel and ths surface it is skidding on?
Good Answers: 123
Re: Torque
07/06/2011 11:55 AM
....multiplied by the square of the pitch ratio.
Bob
Re: Torque
07/07/2011 5:41 PM
If you want to know at what torque wheel nuts must be fastened:
Check the workshop manual for the specific vehicle.
Register to Reply 6 comments
bob c (2); cuba_pete (1); jlstitt (1); jurie sa (1); PWSlack (1)
