I have an issue with two in service boiler feedwater pumps that experience water hammer on start up.
I see that I cannot attach docs to this forum so that makes it difficult for me to show the meat and potato's info about this issue like the drawings and photos of our IP/LP boiler feed water pump system. If anyone wants to do any direct email I am good with that just PM me your address or ask for mine.
Anyway this is the issue, the pumps take condensate water from the deaerator tank and pump it back to the HRSGs. These pumps have bypass recirculation valves on them that returns some water back to the deaerator tank. These recirculation valves are 3" Yaway 9200 ARC valve with a 3" Yarway 9160 Back Pressure Regulator mounted on the inlet of the deaerator tank line from the pump.
The issue we are having is that during pump start up the outlet and bypass lines start vibrating and shaking violently with a lot of hammer noise. This will last until action is taken and the action is to close the pump outlet valve and then slowly open it up. We are unable to just turn the pump on and run it without this hammering occurring. Actions taken to fix this were that the recirculation valves were changed to a different manufacturer and they have been rebuilt a couple of times and additional piping supports were added to stiffen up the system.
The motor driving these Bingham BFW pumps is 150 HP. The pipe between the pump skids and the two HRSGs is 4" and 450 ft long 70% horizontal and 30% vertical in various spots. The DA tank return line is about 40ft primarily vertical.
I have looked into devices like the ones in these links but I have no idea how to size them and believe it or not the venders blew me off saying all I wanted was "free engineering" work, so I am stuck figuring this out on my own and am out of my league for crunching the numbers on something like this.
http://www.shock-guard.com/index-b.htm
http://www.flexicraft.com/Hydropad_Accumulator/Surge/
Anyway if anyone wants to give up some "free engineering" and loves the challenge of solving real world problems I have the opportunity to do so.
Thanks for the help
