Previous in Forum: How To Spec a Solenoid/Valve?   Next in Forum: Data Required For Floating Enquiry For The Exhaust Fan/Blower
ACB
07/09/2011 5:10 AM
How can setup ACB Swithgear. Reset option
Re: ACB
07/09/2011 10:23 AM
Hire a competent electrical engineer who knows how.
Re: ACB
07/10/2011 11:10 AM
What ACB your talking about ? (Brand)
Most is only set the Current and Breaking Time only, some provide In adjustment.
If your ACB using logic control, just replace the logic control. It's troublesome if you want to reset and readjust the control, also need to re-calibration after.
Re: ACB
07/10/2011 3:37 PM
Well if the switchgear is not provided with a built-in reset option, and the switchgear is not provided with a reset option accessory that can be retrofitted to the switchgear, then you generally cannot.
If you have switchgear which has a reset function, try looking in the switchgear manuals.
Jack - Actually sells and tests 'blooming' switchgear.
Register to Reply 3 comments
jack of all trades (1); lyn (1); Romeo2010 (1)
