Previous in Forum: Gaps in Stacked Rotor - Stacking by Shaft Shrinking   Next in Forum: High Efficiency Motors
10 comments
Non-contact Linear Position Sensor
07/11/2011 11:56 AM
Is there a non-contact position sensor which could replace a limit switch and be used to ramp a load to a positive stop via hydraulic proportional valve? Ideally, picking up the approach of the load at about 1 inch and providing analog feedback of voltage or current in order to slow down and stop against a fixed stop (not the switch)?
Factory environment, must be robust.
Pathfinder Tags: non-contact position sensor
Good Answers: 15
Re: Non-contact Linear Position Sensor
07/11/2011 12:25 PM
Proximity switch?
Photo eye?
downhill slide to 112 (damn memor.)
07/11/2011 12:41 PM
You're proposing a much to easy, obvious and cost effective solution. What would be a better suggestion would be ultra-sonic echo location. How about pulsed, phased array radar that utilizes spread spectrum signal processing to make it difficult to counter-measure jam. (That might have some security difficulties. ) Maybe a simple array of infrared HD digital cameras with an AI interface and feedback system to operate the hydraulics.
Good Answers: 918
07/11/2011 12:59 PM
You asked for a linear position sensor and that implies you are not asking for a simple switch that changes state from off to on at a specific point, but gives you a analog voltage proportional to position.
For non contacting measurements you have a few choices:
Optical encoders. These are typically used on CNC or other machines to indicate the precise position of the table or trolley. Many types exist, including some fairly cheap ones (i.e., Absolute Digital Scale) that have a SPC serial data output that you could create an interface to to read the absolute position of the sensor. This may be the most economical way to go, but you need some sort of interface to convert the SPC data to an analog output. A small microcontroller such as a PIC Micro to do that.
Here is a third party SPC interface that may help.
Another accurate sensor is the LVDT (Linear Voltage Differential Transformer). These are more expensive and require a signal conditioner. They can cost hundreds of dollars for the sensor and another $100 for a conditioner amp.
Digikey has an example sensor that measures up to 2" stroke.
You need a signal conditioning amp as well.
Another thought is Hall Effect. However, you will most likely need to make the sensor yourself or pay large sums to get something COTS. The plus side is they can directly provide you with an analog output that is representative of linear position. Longer strokes require some tricks to make them work and can get more complex.
Good Answers: 266
07/11/2011 3:14 PM
some laser measurement devices that can be pretty accurate as long as your range of motion is not over 36".
Good Answers: 130
07/11/2011 10:05 PM
"Factory environment", "at about 1 inch"
If this means the the point you are approaching is constant - why not just use a cushioned cylinder?
If the point is not, then why not just use a deceleration valve linked to a finger, or hinged leading edge?
07/12/2011 12:21 AM
I agree with 34P5
This method is regularly used in pnematics / hydraulics.
Just consult some power hydraulics engineer, he will get that done for you easily
07/12/2011 1:10 AM
Logic is the art of going wrong with confidence. -- Morris Kline
Good Answers: 59
07/12/2011 3:49 AM
YES, it is available.
NO, I would not implement one without a limit switch.
Good Answers: 804
07/12/2011 6:19 PM
There are dozens of different technologies available for this, but which one you would be best served by is going to depend on a lot of other factors. I would start off by examining your linear motion device. If it is a cylinder (i.e. hydraulic cylinder) and it has or can have a magnet in it (as most now do), they you can get a magnetostrictive linear displacement transducer. That is the standard for that type of application. If it's not a cylinder, a laser or IR sensor might make sense if there is a reasonable target to hit and ultrasonic are good for some applications too, especially those where optics might have issues with reflectivity or refraction. If there is a rotary aspect to the motion device, an encoder would work. You also have to define your needs as well: How accurate? What distance, both minimum and maximum? What kind of environmental issues such as temperature, contaminants, vibration, shock, etc.? How are you going to want to mount it? Does it need to be absolute, meaning it knows where it is immediately when it is powered on?
You still have a lot of work to do before you can get meaningful help.
07/13/2011 9:30 AM
GA. The lack of useful, critical information from the OP was exactly why I went into my "snarky" mode earlier. (I must've been having a bad day.) You've done here an excellent job of identifying the critical information that should be known to make an informed selection.
Register to Reply 10 comments
34point5 (1); Anonymous Hero (1); ddk (1); GordieGii (1); gsuhas (1); JRaef (1); leveles (1); ozzb (1); redfred (2)
