Previous in Forum: 3D Printing, Is This for Real?   Next in Forum: Technical Consultation
Grinder Design
07/12/2011 1:31 AM
I need how to design a grinder
Re: grinder
07/12/2011 1:36 AM
The term "grinder" covers several different types of devices. A bench grinder uses abrasive wheels to grind metal or other surfaces. A sewage grinder (pump) chops solid waste into small bits. A coffee grinder chops roasted beans into granules. Etc.
Re: grinder
07/12/2011 2:15 AM
Well let us know when you have worked out a specification (what you want it to do) and then we'll help with any specific problems.
Re: Grinder Design
07/12/2011 1:11 PM
I'm going to assume he means these
Grinders
Photograph from Spine on Flickr
A term used in New England and the Midwest, grinder refers to toasted or warmed subs. In Philly, heroes, grinders, and subs are heated hoagies (depending on what part of Philly you're from). Some might distinguish grinders from toasted subs for having hot fillings to begin with. Jennie Grinders can be found in the Midwest, especially in the Des Moines, Iowa, area, and consist of Italian sausage, ground beef, green peppers, tomato sauce, and mozzarella melted in hoagie rolls.
"It's not the dress that makes you look fat. It's the fat that makes you look fat." - Al Bundy
Re: Grinder Design
07/14/2011 4:01 AM
If you would like a design of a surface grinder, i have quite a detail with me..but as the other Guru's were saying, yup, which grinder are you talking about..
Re: Grinder Design
07/19/2011 1:13 AM
Sounds like you are out of your league
Ask a professional Mechanical Designers & Professional toolmakers
We have designed differnet types of grinders to grind
  • Rubber
  • Minreals
  • Metals
What are you grinding and what type of out put are you expecting in terms of volume and size?
Anthony@alno
www.alnoproductservices.com.au
Anthony@ALNO (1); marses (1); thall (1); Tornado (1); user-deleted-1105 (1)
