Previous in Forum: Grease Pump   Next in Forum: Design of Anchor Bolts for Vertical and Horizontal Pressure Vessels
Coating on CS Fastners
07/12/2011 2:33 AM
Dear All,
I need to have a coating of molybdenum disulphide (anti-seizing) on hot dip galvanized CS studs (SA193Gr.B7) & nuts (SA194Gr.2H).
Are there any problems with respect to process on complying to above requirement.
Re: Coating on CS Fastners
07/12/2011 2:53 AM
Other than just brushing on a dab of MoS2 sufficient to cover the threads of the stud, there shouldn't be much of a problem.
07/12/2011 5:16 AM
Check out Molycoat™ or Lubriplate™ products. (Not an endorsement)
Good Answers: 27
07/13/2011 12:15 PM
You didn't explain why you need the anti-sieze. Obviously, with HDG fasteners one or the other (studs or nuts) have standard threads before galvanizing. Common practice is standard threads on studs or bolts resulting in those threads being oversize after galvanizing. HDG nuts are tapped oversize after galvanizing leaving ungalvanized nut threads (which are still protected by the galvanizing on the studs or bolts as well as the adjacent galvanized coating on the nuts). The zinc coating on the external threads also provides a degree of lubricity.
Register to Reply 3 comments
Bluestone (1); lyn (1); Tornado (1)
