Previous in Forum: Mechanical Estimation   Next in Forum: How do Adsorption Type Hydrogen Dryers Work?
14 comments
Negative Suction Pumping
07/14/2011 5:14 AM
Hi this might seem an easy question to some, so please pardon me.
In many of our applications we need to pump water from an underground pit (usually 3 metres deep), and usually we use a horizontal pump that is placed at ground level. From what I understand, we have two options:
1) Use a normal non-self priming centrifugal pump, and place a foot valve to keep the prime. However foot valve usually leaks, so the pump will lose prime.
2) Use a self-priming pump. Some sources that I come across mention that we should not place suction valves or foot valves because they will just add to the friction loss. However I think foot valve is still necessary. otherwise the suction piping will always be empty after pump stops (pump is usually operated intermittently). Is this correct?
Therefore, Option 2 seems like a no-brainer.
Also, for self-priming pump, the suction piping should be the same size as the pump suction nozzle (generally for other cases the suction piping is larger). I also read that there should be a bleed line going from the discharge piping (before the check valve) so that air can be vented out of the discharge piping during priming.
Please correct me if I've mis-understood anything..thanks!
"Engineers simplify complex problems, and scientists vice versa."
Pathfinder Tags: pump
Re: Negative suction pumping
07/14/2011 5:28 AM
Option 2 has a lot going for it.
A non-return valve has to be provided somewhere in the system, otherwise the pipe contents will run back through the pump into the sump when the pump stops. So the friction loss of the valve still has to be accomodated. Where it goes in the pipework is determined by the available Net Positive Suction Head, with a preference at the inlet to the pump's inlet piping, so as to maintain prime.
07/14/2011 10:32 PM
If non-return or check valve is installed in a)discharge line after the pump outlet it will reduce the load of the pump b)suction it will acts like foot valve and help priming.
pnaban
07/15/2011 3:55 AM
B is correct.
A is incorrect.
07/15/2011 11:17 AM
I believe a)will help to start the pump without creating a back pressure on the impeller
pnaban
Good Answers: 38
Re: Negative Suction Pumping
07/14/2011 8:42 AM
What a nice question !!
I understand exactly what you mean. Please, keep up the good work.
Your question seems to be well worded, in English, correctly spelled and "all caps" is not used in the message. For this particular goofy forum, this type of message surely is a rare treat !!!
With regard to your pump configuration question, you are missing a third option. Consider the use of a priming tank.
Some information is available on:
www.gouldspumps.com
Best regards and keep up the good work....
Good Answers: 48
07/14/2011 11:40 AM
There are different types of self-priming centrif, and much depends on the system in which it is used.
In general, self-priming centrifs do not require a foot valve or any type of non return valve. They are what they say, 'self-priming', so even if the liquid has drained from the suction line, the pump will evacuate the air from the suction line and draw the liquid into the pump. It does this by retaining liquid within the pump body (some pumps have a non-return flap-valve on the suction, most do not) which is mixed with the air and recirculated within the body, evacuating the air through the discharge.
In fact it is better for priming to have as little constriction as possible both on suction and discharge. If there is any constriction on the discharge side, such as a check valve, then a bleed line will be required, otherwise there is nowhere for the air to be evacuated to.
If the suction piping is too large it can extend priming times too much as there is more air to evacuate. Using the same size piping as the suction nozzle is usually the best compromise for priming performance vs. pumping performance.
07/14/2011 3:06 PM
Or option 3: A sump pump.
07/14/2011 9:12 PM
Thanks for all your advice, they really help a lot.
We don't use sump pump for this case as there are chemicals involved and this may lead to corrosion.
I suppose why we always put foot valve even for self-priming pump is to "avoid time delay due to re-priming during start-up" (I don't know how long it takes to re-prime though)
No discharge check valve for self-priming pump? Would that not lead to reverse flow and cause damage to the pump (being centrifugal)?
For a previous project, we used a priming tank when the pump centreline was only slightly higher than the tank outlet (say 400-500mm). Would it work if it is 3000mm? I did see a priming tank at one of the pump manufacturer's testbed facility (similar scenario as this current one) though -- they used vacuum pump to help with sucking the air out of the tank. Now that I recall, they mentioned that it is economical with there are a lot of pumps (then can use common vacuum system), but would be expensive if it is only two pumps involved.
I would appreciate any opinion :)
Good Answers: 48
07/15/2011 5:42 AM
"We don't use sump pump for this case as there are chemicals involved and this may lead to corrosion."
If there are chemicals/corrosion involved then you should keep it as simple as possible, avoiding unnecessary valves, priming pots, etc. A good chemical self-priming centrif (or possibly a vertical lineshaft pump?) would be best. I used to work for a company that made (arguably) the best self-priming centrifs for chemical process applications. Send me a PM if you want further info.
"I suppose why we always put foot valve even for self-priming pump is to "avoid time delay due to re-priming during start-up" (I don't know how long it takes to re-prime though)"
Priming times will depend on many things, including the volume of air to be evacuated, the pump size and speed, the priming efficiency of the pump, etc. We used to consider anything more that 2 minutes to be too long for priming.
"No discharge check valve for self-priming pump? Would that not lead to reverse flow and cause damage to the pump (being centrifugal)?"
There are two routes between suction and discharge, since internal recirculation is necessary during the priming cycle, so you would not necessarily get reverse flow through the impeller when the liquid drains back (except if you are using a standard centrif + priming pot).
07/14/2011 11:13 PM
Is the water clean? Depending on valves to hold prime with dirty water can be annoying. Your multiple applications raise the question, as does "foot valve usually leaks." You don't want an added flow restriction that does not hold prime.
07/14/2011 11:55 PM
For a pump suction head of that value, and because of the corrosive/varied nature of the fluid pumped I would look at a progressive cavity pump rather than a centrifugal. Progressive cavity pumps don't usually like running with dry stators so a "kink" usually needs to be placed in the suction so that when the water runs out the pipe the stator is still submerged. The big advanrage of PC pumps in this application is that they prime very quickly and footvalves are generally not needed unless you have a very long suction.
Having a farm is great provided you don't have to depend on it for a living.
07/15/2011 2:48 AM
There is another method called priming pot. This basically a sealed vessel introduced in the suction line and piping arranged in such a way that the pot is always full of water even if there is no foot valve. The volume of water in the pot is generally kept about 50% more than volume of suction pipe. Once this sealed pot is filled through a filling line , and the pump is started, the pump pumps out the pot water creating suction in the suction pipe thereby drawing water through suction line into the pot and then to the pump.
07/15/2011 1:46 PM
Option 4, You could use a jet pump. They are normally used on shallow water wells. In essence the output pipe is open ended at the bottom of the well. Water is pumped out of a reservoir down the well into a jet that is pointed upward inside the well output pipe. The fast moving stream of water out of this jet, creates a venturi effect that draws water out of the well. The reservoir is refilled from the well discharge and the excess water is used for other purposes.
If you don't mind diluting the contents of your tank as you pump it out, fresh water could be used to feed the jet pump. Then your pump would never have chemicals in it at all.
It gets interesting when you put fuel and oxygen in the same molecule, without allowing them to react, YET!
07/18/2011 3:30 PM
Submersible pump? If there are metals that will make a good check/non-return valve, there should also be submersible pumps that will hold up in the chemicals. With non-corroding materials, several of the other pump options would work OK.
Lehman57
Register to Reply 14 comments
BigPete (1); Holzfeller (2); Kilowatt0 (1); Lapin (1); Learner42 (1); Lehman57 (1); MJCronin (1); pjquek (1); pnaban (2); PWSlack (2); woodpower (1)
