Previous in Forum: Unequal Reactive Loading   Next in Forum: Current Capacity of al./cu. Strips
14 comments
A Few Question About Transformer
07/15/2011 4:13 AM
Hello everybody. I am now studying a subject relating to transformer in Hong Kong. My lecturer ask me some basic questions to let me understand more. would you mind spend some time correct me.
1.what are the purposes of transformer tap change: -To supply a desired voltage to the load -To counter the voltage drops due to the loads -To counter the input supply voltage changes on load -To regulate the active and reactive power flows
Why distribution transformers do not use on-load tap changer?-The volts per turn available in large transformers is quite high and hence a change of even one turn on the LV side represents a large percentage change in the voltage -LV current are normally too large to take out the tapping from the windings -LV winding being the inner winding in a core type transformer adds difficulty of taking out the taps. Type of tap changing: -Off load tap changing and On load tap changing
2. Why is it necessary to work under vacuum environment during oil filling process?To ensure any moisture and air not exist during the oil filling process. Why oil-filled transformer is filled with N2 gas afterward?N2 gas offers better protection against the ingression of moisture and other contaminants that can have a negative effect on the integrity of the transformers insulation system.3. Why the transformer is designed with raditor fins?heat generated by operating transformer which needs to be dissipated by radiators. The large surface area of radiator can help heat dissipation more efficient.4. Transformer winding construction used to have LV windings wounded closer to core and HV windings on the outer side. (core type transformer) Why have new transformers changed to have the HV windings inside while the LV windings outside?~~~>i do not have any idea on this question...is there any web site for me to further study on the winding structure?
Good Answers: 181
Re: A few question about transformer
07/15/2011 5:23 AM
The reason you're "lecturer ask me (you) some basic questions" is for "you" to find the answers.
CR4 is not a homework answer site! Try Google or Wiki
07/15/2011 5:27 AM
Sorry....but i have answer some questions...
But main concern is on question 4...
07/15/2011 9:54 AM
No......
read text book Don't try to get ready made answers.
Good Answers: 11
Re: A Few Question About Transformer
07/15/2011 11:10 AM
4 Core or shell type construction doesn't have anything to do with whether the high voltage winding is on the inside or the outside.
Where the high voltage winding is actually high voltage (say over 1000 to 10,000 volt) it is normally wound on the outside.
07/15/2011 2:57 PM
Watch the Transformer 3 movie....and you will know the answer....
We Stare Because We Care
07/15/2011 7:41 PM
To Banana86: Haha this is a good idea i've watched the movie last week. It is a great idea and i can present the"type" of transformer to my lecturer. HAH
To TonyS and Anonymous Poster #1: First of all i would like to say sorry to you all...I know so many people would like to get the short cut in this forum...I would get the answer on next monday but of coz i will still answer thoser answer and close the post...Thank you^^
To Carl Pugh :Thank you for your notification!!^^ i may change some key words in this question. Since we have to discuss the ready power transmission and distribution transformer in Hong Kong which are step down Tx. (Which mean the transformer in the transmission and distribution network in Hong Kong, 400kV-11kV and 11kV-380V)~~>if i have some mistake please rise it...since i have learnt power system just a few weeks....So the words LV windings will be the secondary winding while the HV windings will be primary winding.
My lecturer just ask in this way but i have to trust him and try to give him an answer...haha=.= My friend explain why the captioned tranditional winding structure (HV outside and LV inside) Of coz my lecturer has some other questions like why the tx core has stepped core structure. I will try my best to find all the answer in these 2 days. Thank you so much.^^
07/16/2011 12:00 AM
I like when people do come back despite our a bit harsh words.
You see in our old generation we had text books only and no computers.
To find an answer hence - no search features- go through the book (plural in quite a few cases) and then the answer might be composed (it won't be available in so many words)
The advantage was that just by going throught it- you visualise, read something irrelevant (to the current assignment) and things go into memory, at least traces of it and you know where to look for answer to a given question.
This is why we remember the points even after 30+ years of leaving the colleges and that too despite many of us are not in the field of application too.
Remember - faster you get a solution, quicker you forget.
As far your question 4 is concerned - what is the erason of placement of windings outside or inside?
Think about stresses - mechanical (That too happen due to current carrying conductor in a magnetic field) and electrical (of course insulation).
Advice - since you seem to be one who tries or should - Mull over the problem - why a particular feature was there - then why was it changed - must have been due to
efficiency - ie better flux linkages
or failures -
Which one will be here? One of them (and it didn't compromise the other) or both ?
07/16/2011 1:00 AM
Thank you so much!!! I will try my best to get the answer!^^
07/16/2011 5:24 AM
or failures -
Thank you so much!! Your comment give me some interesting direction on this topic. I spend some time on learning the mechanical stress on tx windings. I hope that i can find more supporting reason on my question. But my friend still standing strong on the reason of insulation. (HV need higher insulation with the core, hence HV winding have to be the outermost winding) ... I have to study it more.....THanks again!!
07/16/2011 7:36 AM
HV = say 11KV
LV = 415V
Core = 0 V
HV-LV = 10585V
HV-Core = 11000 V
(Do they differ much? ask your friend. I am not going to extremes where HV may be 400KV and LV may be 11KV.)
07/16/2011 7:50 AM
Also find out something about interleaving of windings.
07/18/2011 9:05 PM
My lecturer ans on question4:
I recently visited the Tx factory and found this winding construction. So i am just interested to ask this question..
He said this winding construction mostly found in some some voltage tx. The high volt winding is thin. It may easily broken when the HV winding is wounded around on the outermost diameter.
But for those winding construction seen in the supposed tx factory. He has no more comment on this question. =.=
Good Answers: 59
07/16/2011 2:25 AM
You sound like a nice guy. But, homeworks supposed to be worked out by the students themselves. That is the homework FOR, guys!!
07/16/2011 2:35 AM
Thank you all spend so much time to share the experience. My lecturer always ask me to read read and read also. I hope I can solve those problems tomorrow. Thanks again!
Register to Reply 14 comments
Anonymous Poster (4); Banana86 (1); Carl Pugh (1); leveles (1); TonyS (1); wymanlam0420 (6)
