Previous in Forum: NEC Rule for Sizing Star-Delta Contactor   Next in Forum: Online Motor Health Analysis for 6000HP DC Motor
How to Calculate NGR?
07/18/2011 7:19 AM
We have 50kA, 1 sec S/C fault current level for transformer of 11/3.3 kV having Dyn11 vector group. The value of NGR is 6.92A. How is this NGR value calculated?
Re: How to Calculate NGR?
07/18/2011 12:51 PM
I do not believe "The value of NGR is 6.92A". The value of NGR is in ohms. So you can use Ohm's law to calculate the value of the resistor.
I = E/R or R = E/I. Don't forget the calculate the required wattage.
Good Answers: 244
07/19/2011 9:00 AM
Good Answers: 170
07/26/2011 11:28 AM
NGR Value (in Ohms) = Phase Voltage of the system / desired earth fault current.
In your case, the desired earth fault current (on the 3.3kV star side, I presume), is decided as 6.92A. Hence, the Ohmic value of the NGR is: 275 Ohms.
Register to Reply 3 comments
electricalexpert65 (1); msamad (1); wareagle (1)
