Previous in Forum: Online Motor Health Analysis for 6000HP DC Motor   Next in Forum: How to Connect a Lamp
8 comments
Star Point
07/18/2011 2:19 PM
Dear All,
please tell me that can we use kirchof current law on star point of star connection. if not then please explain that why on star point all currents become zero.
thanks.
Ikram Shehzad
Re: Star Point
07/18/2011 3:33 PM
In order for three phase currents to result in zero at the star connection, they must be 120 degrees out of phase and equal magnitudes. Why would you think Kirchhoff's Law would not work? read all of this.
Re: Star Point
07/19/2011 2:32 AM
Note that Star point will be zero only at balanced load. Also you can use the Kirchoff's current law to any node of current analyse. Here also you can use the Kirchoff's Current Law...
Abdullah.
Re: Star Point
07/19/2011 3:55 AM
Kirchoff's law can be applied anywhere that there are not electrons spewing out the ends or sides of conductors.
Re: Star Point
07/19/2011 2:06 PM
Quote Abdullah "Note that Star point will be zero only at balanced load."
The loads must have the same power factor. You could have all 3 phases reading 100 amps but have different phase angles and would not sum to zero at the star node.
Re: Star Point
07/19/2011 11:04 PM
I said Balance Load. I does consider the phase angle too....
Re: Star Point
07/19/2011 3:43 PM
I think that some of this stuff you must just think it over...may be you ment that your voltage in the star point is zero...your current are summulating through your star point at 50cps
Re: Star Point
07/19/2011 4:59 PM
AP#1 I believe if you add Ia /0 deg + Ib /120 deg + Ic /ang 240 deg you will get zero. You can add them using vectors very easily. If you assume the magnitude of I = 1 then
Ia = 1 + j0
Ib = -0.5 + J 0.886
Ic = -0.5 - j 0.866
total = 0
Re: Star Point
07/20/2011 12:29 AM
you already mentioned kirchof's current law...the basic principle is taking a node (a point perhaps) where you start your assumptions of your calculations...note that in kirchof's method you emphasize the direction in which current flows...now, consider a star connection....each phase consist a phase current having a magnitude and direction (say 120 elect. degrees), now this quantity becomes a vector quantity...and finally, consider the star point as your "node", apply kirchof's law and consider the directions..sum it up...then your answer will still be zero....
..ps...assume a balanced system....
ΕΣ
take care of your seconds and the minute will take care of itself..
Register to Reply 8 comments
alnashadh (2); Anonymous Poster (1); PWSlack (1); rockraiden (1); wareagle (3)
