Previous in Forum: Ground Fault   Next in Forum: How Often do VSD's Save Money
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
Identification of Magnets
07/20/2011 2:01 AM
Hello everybody,
I have one permanent magnet motor. I found that the rotor is having NdFeB magnets. Now i am in confusion that whether it is sintered NdFeB magnet or bonded NdFeB magnet? So i am thinking how to identify this. Is it possible only by measuring Magnetic flux density value of magnet?
Hoping for your valuable suggestions
Regards,
sharath
you need to go, to get something
Good Answers: 53
Re: Identification of Magnets
07/20/2011 10:59 AM
Sintered type are normally plated and give high flux density, on other hand bonded magnet will have some color like brown depending on the resin used for bonding, and will show lower magnetic flux density than of former one.You can also differentiate them by scratching or by checking hardness.
07/21/2011 1:51 AM
Dear Rakesh,
Thank you very much for your suggestion. But the magnet is assembled in rotor, so neither i can scratch it nor open it to check its hardness. so what can i do for it?
Please excuse me if my question is very basic.
Regards,
sharath
Good Answers: 25
07/21/2011 7:53 AM
I understand it is high torque motor which mostly used for feeding rolls in machine. Why you want to study rotor magnets?. Is motor under breakdown?. Better contact mfr.
07/22/2011 2:01 PM
I have measured the flux density value of the magnet by gaussmeter. The magnetic flux density value on the surface is coming in the range of 400 to 500 mT. so i can consider it as sintered NdFeB magnet, since sintered magnets give more energy product than bonded.
Am i right?
Register to Reply 4 comments
rakesh_semwal (1); sharath4 (2); suresh sharma (1)
You might be interested in: Industrial Magnets, Rare-Earth Magnets, Magnet Wire
